Go Back   16v Mini Club Forums > General Public Area > Non 16v Mini Chat
Old 04-01-2019, 10:58 AM   #16
I bought one of these a few weeks ago:
https://www.toolstop.co.uk/sealey-cp...SABEgLdJPD_BwE
It's brilliant, it works as a normal ratchet so you can undo very tight bolts by hand then wizz it off and when tightening you can wizz it up then just give it a check by hand (most bolts are tightened enough though). and is pretty compact so will fit most places a normal ratchet will (in fact can be better as you don't need room to crank it). saves a lot of time and effort and the batteries seem to last ages
Old 04-01-2019, 11:24 AM   #17
Link doesn't works for me
Old 04-01-2019, 11:53 AM   #18
No worries I've nabbed the product number out of the link and Googled it
I've been inspired to get one but I've gone for the 50lb/ft version rather than the 33lb/ft, Amazon had a good deal on a kit (wrench, 2 batteries, charger and carry bag), rrp was over 500, I got it for 199
Old 11-01-2019, 09:17 PM   #19
evolotion
evolotion's Avatar
I use my tools every day in work , and am a bit of a tart so all my gear is snap-on. slowly but surely replacing all my ni-cd stuff with newer lithium stuff. tbo 10-15 years ago no one could touch the snap-on cordless stuff, the drill could snap my wrist and impact was superb, nowadays technology has caught up. most any current brand of cordless tool has plenty of power IMHO the only reason I stuck with snap-on is their warranty/repair service and longevity of the tools I love them, but not sure id recommend for a home gamer they are pretty low on the "bang for buck" scale.
on the right angle stuff, I have the snap on battery ratchet #CTR761B its a stout little piece but its not up to impact levels of torque output, I have heard good things about the milwaukee M18BRAIW which is a genuine right angle impact wrench, but never ran into anyone I know who has one to compare.
11.9@118 :)
Denis.
evolotion is offline   Reply With Quote
Old 13-01-2019, 06:00 PM   #20
Kam
Kam's Avatar
I picked up this impact wrench from Machine Mart a while back, I know your wanting cordless Gaz but it is corded, however with 450nm for 72 it is excellent power to cost ratio
https://www.machinemart.co.uk/p/clar...impact-wrench/
Haven't found anything yet it can't undo
My mini has got nothing to prove so nothing to lose
Kam is offline   Reply With Quote
