Old 09-12-2017, 08:29 PM   #1
mm man
Default Brake knowledge needed
I have spent hours searching here but every time I think I have found what I am looking for then either all photos have been removed or the forums crash has deleted links as posts are to old .
I am looking for a brake pedal box set up total in car if possible floor mounted as no room on bulk head .( I can fit remote reservoirs )
I have seen all the universal ones but what size masters do I need
My set up is
Front 4 pots mg metro
Rears Suzuki swift rear Calipers (discs)
And I have also been advised to go hydraulic clutch
How do I work out what I need
Would this do the job
https://www.ebay.co.uk/itm/OBP-Unive...19.m1438.l2649
https://www.ebay.co.uk/itm/Kit-Car-H...p2056016.l4276
I am a simple type I don’t have a masters in mathematics so all help is appreciated the simpler the better .
Any photos of builds would be super helpful.
Old 10-12-2017, 09:27 AM   #2
For Info: The early OBP units were very flimsy, as stated by some mini users who sent them back. I believe they have made them a bit sturdier now, but have no proof. Maybe some people on here have them and can advise.
Old 10-12-2017, 06:37 PM   #3
joltfreak
joltfreak's Avatar
ECU: Standard-ish
I went with the Wilwood brake and clutch with remote reservoirs in my mini
