Old 04-12-2017, 05:49 PM   #1
Mini Vlatko
Mini Vlatko's Avatar
Default Suzuki ITB idle set?
How to set the idle on Suzuki Throttle Bodies with MS?
Do I set it manualy?
Old 04-12-2017, 07:38 PM   #2
Purtsi
Purtsi's Avatar
Yes. There's one screw that you turn just like with a single TB. Just make sure that all flaps are in sync and open the same amount.
I have a cunning plan...
Old 05-12-2017, 06:40 AM   #3
Mini Vlatko
Thanks Purtsi but I must be honest with you, I didn't noticed any screws for that kind of adjustment...although there is some kind of a small cable with some sort of screw on it but I removed it cause I thought it was for choke or something...will look into it and take pic today
Old 05-12-2017, 05:57 PM   #4
Mini Vlatko
Like I said there was a cable and it was for idle adjustment on a bike but I really didn't need it cause now is totally accessible...
So I cut the cable off and made a groove for screwdriver
