Old 23-11-2017, 03:03 PM   #1
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
Default Electric waterpump modification
Hi!
need som help please!
Do i need to move the heater/aux rad return to the "sucking" before the pump?
Or I'm i fine with the std setup with the return in the "pressurized" pipe that i have created by mowing the pump downstream
or maybe i doesn't matter where in the stream the return hooks up
not good att the law of physics
mec pump by G13B, on Flickr
elpump by G13B, on Flickr
Old 23-11-2017, 06:30 PM   #2
joltfreak
joltfreak's Avatar
ECU: Standard-ish
I wouldn’t think it would matter as the whole system is under pressure and as long as it moving the fluid.
Old 23-11-2017, 07:40 PM   #3
Marcus Nordblom
ECU: 40mm mikuni rs
I’m leaning against that theory too, picturing the smaller hose as a connecting river branch
Old 28-11-2017, 11:07 AM   #4
Marcus Nordblom
ECU: 40mm mikuni rs
After some googeling I have decided to reroute anyway, from heater matrix to radiator bottom hose, (have ordered a new hose with heater outlet)
