Old 03-01-2013, 12:39 PM   #31
Kaison
Kaison's Avatar
Thanks!
Yeah it's interesting to see!
Seeing the times makes me want to build something all round that blows them all out of the water!
Maybe I just need a GTM coupe!
I only bow under braking.
Old 03-01-2013, 01:00 PM   #32
Jerry's Van will be a contender when its running
Old 03-01-2013, 01:23 PM   #33
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
Originally Posted by Kaison View Post
Thanks!
if mine was just a 1/4 mile car it would be alot quicker than it is and certainly wouldnt be na, unfortunately i wanted mine to go round corners and be driveable on the road
miniwade is offline   Reply With Quote
Old 03-01-2013, 01:32 PM   #34
Kaison
Kaison's Avatar
So you don't think a fighter jet engine sticking out the back of a Mayfair shell would take a corner or get me to the chip shop in comfort?
Old 03-01-2013, 01:39 PM   #35
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
it'll be fine bro
Old 03-01-2013, 01:49 PM   #36
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
if you bolt a laziboy chair in there you might be ok pal
Old 03-01-2013, 02:07 PM   #37
Kaison
Kaison's Avatar
You've given me the best idea ever Wade, I need a bigger car!
Arm rests on both sides, up right position with a reclined position only a lever away, on sliding rails for short and tall people. . . It'll need cutting a lot. . . might be better to just use the reclining mechanism and get an upholsterer to make the seating part, would need to be narrower than usual to keep you in tight. Oh this would be epic. . . Reclined at the traffic lights, then with an easy movement, you're back up right and driving away at MK2
Sounds comfortable!
Old 03-01-2013, 02:39 PM   #38
ivanhoew
kaison ,will you be making the order on the chart like a leaderboard ,or random times as it is now ?
i agree with wade ,if i had a lsd and yoks and 100kg less weight it would be a fair bit quicker , but not worth it for the outlay for a couple of days a year ,when i drive it year round hence the cheap falkens .
13.13@109.1mph..700kg,falken 165 ,5 port A series, 19psi..open diff.
my channel..
http://www.youtube.com/user/legrandphromage
ivanhoew is offline   Reply With Quote
Old 03-01-2013, 02:57 PM   #39
any 4wd times yet ??
Old 03-01-2013, 03:07 PM   #40
Kaison
Kaison's Avatar
Ivan, at the top of the chart, you can click to order them any way you like, slowest or quickest 1/4 or 1/8, or arrange them to Honda only, or AWD. . .
Shaun, there are multiple AWD times.
Old 03-01-2013, 03:08 PM   #41
Yes Hayling_Mini 12.37 ET for 1/4 mile.
Old 03-01-2013, 03:27 PM   #42
4 wd is unessesary,, have some of that,,ive been asking for proof but no ones listning,,
i dont blame you b,t,way,lol
Old 03-01-2013, 07:19 PM   #43
k20/k24 allmotor
k20/k24 allmotor's Avatar
CC: 1998.2
ECU: honda stock
My slip!
Old 03-01-2013, 07:48 PM   #44
Maybe not as impressive as most but here it is.
I did alternate runs with my mate Martyn.
Could do better off the mark so hoping for better results next time.
My Mini is a 1.8 Rover VVC engined (not modified) with close ratio PG1 gearbox, standard ECU, 2" RC40 no cat exhaust, Watson's subframe kit, Metro brakes and Honda seats. All steel body inc steel welded front. Metro 13" alloys fitted with 175x50x13 Yokohama A539 tyres.
Old 03-01-2013, 08:03 PM   #45
Kaison
Kaison's Avatar
Not a bad effort pal, can I get some specs of the car like mentioned on the second post?
