Old 02-01-2013, 07:34 PM   #16
ivanhoew
Originally Posted by Kaison View Post
I just noticed the typeo on the picture posted, it's been rectified in the file.
I have noticed a disparity on DT's between Station Wagon and ivanhoew's. . .
At the 8th mile points, Station Wagon seems to be in the lead by 0.16 seconds but with a lower speed of 82MPH compared to ivanhoew's 88.65. - This is totally expected, Station Wagon has slicks and doesn't show his 60ft of anything before the 8th mile, so it's expected he had a smoother launch. But it gets weird when you look at the 1/4 point.
ivanhoew's finished .07 seconds later but again has the higher velocity (by a bigger margin)
Now, I'm not saying either of them are lying, maybe they got their figures slightly wrong, I have done so numerous times doing this. But maybe there's a genuine reason for this someone could explain?
I only bring it up because I have vague memories of this happening before.
also.... roundnose ,1310cc ,turbocharged..fwd..avon park july 2012.
13.13@109.1mph..700kg,falken 165 ,5 port A series, 19psi..open diff.
my channel..
http://www.youtube.com/user/legrandphromage
ivanhoew is offline   Reply With Quote
Old 02-01-2013, 08:12 PM   #17
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
this is my timeslip with my runs from mitp, my best run was the 2nd one down.
miniwade is offline   Reply With Quote
Old 02-01-2013, 08:27 PM   #18
Kaison
Kaison's Avatar
Great stuff!
I only bow under braking.
Old 02-01-2013, 10:58 PM   #19
Kam
Kam's Avatar
As you say slicks helped station on launch but then the weight factor kicked in and ivans did the rest? plausible?
Old 03-01-2013, 12:46 AM   #20
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
Ill put what i can remember.. my time slips are in the post with my mini lol
Wilp99
Reaction Time ??
60ft--2.21
1/8 Time and MPH--??
1/4 Time and MPH--13.7@97.9
Team--Honda
Engine--B18 stock everything internals/stock itr cams (built by me)
Driveline type--FWD/3.7 watsons FD
Differential--LSD
Aspiration--N/A
Shell type--Clubman
Weight--not sure but must be pushing ~800kilos
Tyre choice--a048
Track--Santa Pod
Date of run--??
will post up slip when they get here.. then there will be a follow up slip from here.
Old 03-01-2013, 04:44 AM   #21
Kaison
Kaison's Avatar
Wilp, would be interesting to see what your alien climate does to effect the times! - Our wet climates can really slow you down!
Old 03-01-2013, 04:45 AM   #22
Station Wagon
Station Wagon's Avatar
ECU: Spoon
My time is with 13" road legal(Toyo Poxes RA-1) tires and 1500pounds is weight with me inside
Difference in speed with Wade is also impressive.
Station Wagon is offline   Reply With Quote
Old 03-01-2013, 04:47 AM   #23
Kaison
Kaison's Avatar
Yeah it's just from the 1/8 point, you've got someone already at a faster time and by the finish line he's going even faster than the previous guy, so surely he'd hit the finish line in a quicker time.
Old 03-01-2013, 06:59 AM   #24
ivanhoew
mine was 620kg no driver , i weigh around 85kg so total weight was 1551 lbs or 705kg.
my channel..
Old 03-01-2013, 07:48 AM   #25
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
I thought I was ding well with my terminal speed with a flat fronted clubman but your 109mph terminal on road tyres is bloody good,
You must have some grunt in that b18b engine, what sort of power do you think your running?
From memory mine was 720-740kg with me inside ( I'm only little lol)
Old 03-01-2013, 07:49 AM   #26
Kaison
Kaison's Avatar
Thanks Ivan. I hope you like the new table on the original post, page 1 - I'm continuously updating.
PS, is yours supercharged or turbo, and is a roundnose or some other shell type?
Old 03-01-2013, 09:10 AM   #27
ivanhoew
its the test car for the gt17 turbocharger conversion , frustratingly it was better on top end in 2010 ,but i got massive wheelspin on the 13.13 run at 3rd gear .its a round nose .falken tyres , open diff ,huge grip problems lol.
2010 speeds...
my channel..
Old 03-01-2013, 09:42 AM   #28
Kaison
Kaison's Avatar
Very interesting stuff!
Old 03-01-2013, 12:09 PM   #29
Hayling mini
Hayling mini's Avatar
CC: 1340
ECU: Haltech
Here is my time slip:
Video of run:
AWD, 1300 Suzuki engine, TD04 Turbo (22PSI), Toyo R888 tyres, LSD front & rear. No NOS.
Old 03-01-2013, 12:30 PM   #30
Kam
Kam's Avatar
New charts looking good Kaison, when you look at the top times it quite something when you see weemans time with all NA power and the others are using nitrous hits etc
