Old 29-11-2017, 07:00 AM   #1
BLMC VTEC
BLMC VTEC's Avatar
ECU: Gizzmo p30
Default front seats on adjustable rails
getting through the final stages of my mock up before i strip for panel and paint. im abit stuck on what seats/assembly to use. down in nz we have quite abit of japanese cars to source parts.
i would like seats with rails as i would like access to the rear seat. many of us down here have used early 1990s honda prelude setup which worked well but i figure must be some nice seats that come from a midget car similar to the mini.
thoughts please
BLMC VTEC is offline   Reply With Quote
Old 29-11-2017, 04:12 PM   #2
i think the later mini seats with headrests are a good thing, they fit well ect,
midget seats are worse or if not worce the same as mini but bolt down solid, hondas seem popular,
Old 29-11-2017, 06:02 PM   #3
Mazda MX5 Seats work well in a Mini
InstantCustard is online now   Reply With Quote
Old 29-11-2017, 07:28 PM   #4
I have seen Mazda RX8 seats used as well.
gadget555 is online now   Reply With Quote
Old 30-11-2017, 02:20 AM   #5
I have Honda Prelude seats in mine. So does Keith. They use 4 bolts and a support tube on the back mounts. I have an up turned bolt welded to the cross member for front mount.
My son rolled a Mini 2 years ago using this setup and claims this helped him walk away with only a bump on the elbow. The car had been bought only a month earlier with bucket seats that tipped and were not fastened at the rear.
I can highly recommend using Honda Prelude seats.
Old 30-11-2017, 08:21 AM   #6
I can also recommend the prelude seats, they are very comfy and supportive. I made brackets that bolt to the original mounting points with a bolt welded to the top part of the bracket to mount the seat to and a frame for the back to bolt down to the floor.
Old 30-11-2017, 08:44 AM   #7
I had Mx5 seats then Alfa GTV seats in my other mini
Old 01-12-2017, 09:55 AM   #8
BLMC VTEC
BLMC VTEC's Avatar
ECU: Gizzmo p30
i like the idea of late model mini seats but those are abit uncommon down here, plently pre 1980 minis.
I will have to make enquiries into those.
My other mini has early 90s honda prelude seats and i have to say it doesnt look like you have to do a lot of work to fit them and they not to large for the interior and they are comfortable.
Old 01-12-2017, 10:27 AM   #9
Ideally I'd like some seats that slide forward when the back rest is tilted forward to ease access. I had a set of these in an old 2 door Daihatsu Mira which ere great for getting in and out of the back seats
Old 01-12-2017, 07:50 PM   #10
gonk43
gonk43's Avatar
ECU: Honda 0BD1
I have welded in another crossmember, then installed saab 900 seats.
They fit, but no room for centre console if you want one
gonk43 is offline   Reply With Quote
