Old 30-03-2018, 08:05 PM   #631
Nice alloys.
I got same one needs refurb. Just in case I want to go back to 10".
Good Luck!
Old 31-03-2018, 02:56 PM   #632
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
Originally Posted by Purtsi View Post
It'll pass the sounds great test with ease
Did you go through a similar registration in Finland?
Old 31-03-2018, 03:47 PM   #633
Purtsi
Purtsi's Avatar
Well, we don't have a possibility to get highly modified cars on the road because if 50% or more parts have changed, the car will be classified as a new car which then means you have to pay the taxes of the new car + you have to get through all sorts of tests which are very expensive. I have not heard anyone to go through that.
So what we do then? We keep the changed parts to minimum (or don't tell about them at mot). We get dyno sheets that show that the power increase isn't more than 25% etc..
And then there are some cars on the road with +900hp with heavy modifications. Don't ask me how it's done, friendly mot tester maybe...
I have a cunning plan...
Old 31-03-2018, 04:26 PM   #634
Marcus Nordblom
ECU: 40mm mikuni rs
Ok, sounds not that easy Swedish system is actually very good, you get a personal sfro Guy that does the scrutinering and helping you out with solutions to get the car on the road
Old 31-03-2018, 04:31 PM   #635
Marcus Nordblom
ECU: 40mm mikuni rs
Well my Monaco’s got under the cage, not allowed on the street... I had these grp gt-seats that kind of curves forward at the head and clears the cage and yet maintaining a good driving position easier than moving the cage, they are super light as a bonus!
Old 31-03-2018, 04:32 PM   #636
Purtsi
Purtsi's Avatar
Yeah. You have a different approach there as you're given solutions, we're given problems.
Old 31-03-2018, 04:35 PM   #637
Marcus Nordblom
ECU: 40mm mikuni rs
Can you buy a modified car in Sweden and bring to Finland by any chance?
Old 31-03-2018, 09:13 PM   #638
Purtsi
Purtsi's Avatar
I think it depends on if the car is registered as what it came from the factory or if it's self-built from the ground up which most likely will be a no-no. Also if it's from '77 or older it helps as before that you don't need to have the emissions test and from '94 onwards it's even more strict.
Anyhow, if I remember correctly there's one Pimlico Mini in Finland that can't be put on the road because it's not 'mini enough' or some sort.
Old 02-04-2018, 09:23 PM   #639
Marcus Nordblom
ECU: 40mm mikuni rs
Seats in, let the torture begin, race coils...bye bye pelvis
Old 04-04-2018, 09:20 PM   #640
Marcus Nordblom
ECU: 40mm mikuni rs
Some more work Done, bracing up the steering column, now its rock solid
Old 05-04-2018, 06:25 PM   #641
Marcus Nordblom
ECU: 40mm mikuni rs
Snap off, Swedish made concentric = no play
Old 10-04-2018, 07:34 PM   #642
Marcus Nordblom
ECU: 40mm mikuni rs
dirty tricks switches
Old 19-08-2018, 05:22 PM   #643
Marcus Nordblom
ECU: 40mm mikuni rs
On the road for a short while, Brooke the Engine 2/3 piston is loose after examination head and CAMs Looks intact
Old 20-08-2018, 09:06 PM   #644
Marcus Nordblom
ECU: 40mm mikuni rs
Have dismantled my gearbox in order to fit the gripper diff, holy cow there is alot that can go wrong when putting it together
Used this excellent guide:
https://web.archive.org/web/20131018...hp?f=9&t=42589
Old 21-08-2018, 05:48 AM   #645
cedric998
curious to know what broke in your engine. did it "go" at high rews or was it more or less normal use ??
brgds
chris
