Old 28-05-2019, 06:09 PM   #1
Default King racing bearings
Regarding engine bearings, Know there is a LOT of Numbers and stuff on the crank, block etc, only finds std and 20+ or something like that.
Should I just go for std if the crank is in good nick? Plastigauge them and too tight lap the crank in the lathe with some superfine wet?
I have a couple of cranks to match
Have been looking at King “black racing”
Good choice?
Old 28-05-2019, 08:06 PM   #2
My race engine builder told me that King bearing is what he use.
He has 1755Bhp mk2 Ford Cortina.
So it must be OK.
Old 28-05-2019, 11:05 PM   #3
So it must be OK.
Guess im ok with BhP target 10 times lower then
Thanks
