Go Back   16v Mini Club Forums > General Public Area > General 16v Mini Chat > 16v Mini Videos
Old 16-06-2017, 03:21 AM   #1
Default who is this?
info? fucKing monching up cars like they stood still,
Old 16-06-2017, 06:08 AM   #2
One thing the 3 Sisters track is good for are the drivers which see you coming up behind them and they let you go. You wouldn't want to race here as there simple isn't enough space to pass.
The rear wheel drive BMW's and Escort just want to play at drifting. You can see they are quicker than the Mini but decide to allow it to pass.
Fair play to the guy, it's goes and handles well. He's getting 85mph on the back straight. We were getting over 80 in the wet. Not sure if changing gear at any point would help.
Think I'm going on Sunday. I don't have my camera though.
No idea who the guy is though.
Old 16-06-2017, 08:00 AM   #3
Tamstein
ECU: Don't yet have one
Thought I was going slightly nuts at first. watching without sound at work I ended up going through it a second time focusing on the gearstick alone just to make sure haha
Tamstein is offline   Reply With Quote
Old 16-06-2017, 08:02 AM   #4
He uses the astra gte digi dash like I do, so unless he has a speedo healer then the figures being displayed will not be correct because the GTE's used 14" wheels with 60 series tyres. I use a speedo healer developed by a Vaux guy and its spot on with sat nav. Agoaty is spot on with what he said. This track is tight and hard to pass, not high speed although I managed to have a fairly spectacular crash in a Formula Ford there
Old 19-06-2017, 11:15 PM   #5
well, found this> 1.4 ??
Old 19-06-2017, 11:30 PM   #6
ear
