Old 18-06-2018, 06:25 PM   #931
I see youíve got far with the other shell! LMAO!
Your vids crack me up, keep em coming
Old 19-06-2018, 11:49 AM   #932
Originally Posted by NudgerSS View Post
These videos make me smile
At least you have sence of humer!!
You know "rare up north"
If you're not ruff. You can touch me ,
Old 19-06-2018, 12:03 PM   #933
Yes frames off now and gone to Martin,
Then he finds out that his shell has had the rear floor totally
Flat plated so no heel bord for frame, opps
Don't ask!!
Vids lol I dicided to do vids as YouTube seems safe,
Ther a pain to make and get points across,
Building is a pain but look forward to the driving ones later,
My aim is to get dislikes for being cruel to the mini!!!
Old 26-06-2018, 07:46 PM   #934
Been chasing a turn over by key, I did fit a push button
And it won't work so been untraceing that banana! Not in vid,
Got it to turn on black box, looking for pump feed and that's backwards to coz it is linked up to a really, yes a relay due to E,C,U now gone but still leaving it's mess!
https://youtu.be/tV1yTqB-I2Y
Old 26-06-2018, 08:09 PM   #935
Cracking on there Shaun! Plenty of progress.
Will see it moving shortly Iíd have thought?!
Old 27-06-2018, 02:03 PM   #936
Thanks for encouragement, yes progress is good,
I'm stuck in a way! That, do I or don't I do that job now way,
I finding that desition hard to make,
I say( I will paint the tank later, Sunday 1 hour jobs !
I was Shure I was fitting the exsust system last week,
Never happened , I have to do the brakes even though the backs where all brand new , I bet they are seazed!
Anyway forget that and exsust and start up next will give
A boost,
Old 03-07-2018, 08:42 PM   #937
Brakes are new like the day they was put there, something is on my side ,
I also discover my c,v boots are not correct ,!!
My fault but I have 6 mm of rubber layed flat on c,v and about 5 mm sacureing clip,
I want 10 or 12 mm of rubber,, and there is room for it,
https://youtu.be/BSm0aY83-E0
Old 03-07-2018, 09:48 PM   #938
You looked at my suggestion for the pedal yet me luvver?
Old 03-07-2018, 10:01 PM   #939
Not yet danno, I said in my head I would fit exsust
2 weeks ago , I even believed me lol
So felt the need to get it on ,
At least I can sit and rev it with 1 inch of throttle lol,
Old 03-07-2018, 10:04 PM   #940
Must be like an on/off switch!
Im getting nervous watching you crawl under that car, can I send you some axle stands?
Old 03-07-2018, 10:10 PM   #941
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
You need to move where the cable is attached to the pedal down a bit and then youíll have more pedal to throttle movement.
Old 03-07-2018, 10:12 PM   #942
Default Ive got redtop tiger power.
Exactly what I suggested.
If I said it and John said it, then itís gotta work!
Old 03-07-2018, 10:14 PM   #943
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Well they say great minds think alike so i suppose it must work at the other end of the scale too...
Old 03-07-2018, 10:34 PM   #944
I feard that, that end of cable near pedal has a solid lump on
And it's solid in a block that slides into Pedel,
Just cut it I suppose , must be easy join after them god damm excuse for carbs ,end)
Old 04-07-2018, 06:19 PM   #945
Just watched the video. Another classic episode if I may say so.
Must feel good to get it turning over, actually running in next one hopefully.
I have a concern regarding running fuel pipes through sheet steel, without using rubber grommets. It's only a matter of time before one cuts the pipe with untold consequences.
Keep at it my friend, soon be done...
