Old 21-12-2017, 11:02 AM   #1
benisaac
Default Intake air filter
Is an intake air filter absolutely necessary?? I have seen pics which seem to imply some people aren't using one.
I'm struggling for space as I'm in a standard round nose with the bulkhead mods, would probably need to have a 90deg bend immediately off the intake, then try to put a filter on there but most filters seem to be fixed in shape which would make this tricky - unless anyone knows of a foam air filter that can be forced into position?!
benisaac is offline   Reply With Quote
Old 22-12-2017, 12:08 AM   #2
joltfreak
joltfreak's Avatar
ECU: Standard-ish
I picked some alloy tube with a 90 degree bend and cut it to suit.
[URL=http://s974.photobucket.com/user/minimeetnorth/media/Mini%20Van/IMG_0215_zps1ssaifmc.jpg.html][/URL
Old 22-12-2017, 09:29 AM   #3
This is just an ITG foam sock filter on the end of the TB held on with cable ties
Old 22-12-2017, 10:57 AM   #4
Kam
Kam's Avatar
Another alternative
Depending on the size of the throttle body you may be able to route the piping under the brake servo (if you have one) using a flexible ducting like so
Mines is a 68mm throttle body so the ducting is quite big, plus its turbo wrapped (so adding extra mm) and routed 90 degree straightaway then under the servo, it sits near to the side of the radiator with a shielding between the two. Ducting is under the car looping up towards it
Ok the bad things, its a pig to fit with the servo in place, much easier to remove the servo to start with then throw it in and then the servo will hold everything down tight
Having the braided flexi pipes on the servo are a godsend anyway and I would always recommend them especially with the above
Old 27-12-2017, 08:53 AM   #5
Emily Koon
maxspeedingrods, this site has coilovers, turbo, connecting rods, air suspension, air bag and other parts, they are having sales now
Emily Koon is offline   Reply With Quote
Old 29-12-2017, 07:39 AM   #6
benisaac
Thanks guys. I may be able to introduce something along the lines of yours Kam, as I know it’s best to have one!
Ben
Tags
air, filter, inlet, manifold
