Old 07-11-2017, 04:42 PM   #1
lebarron
Default B16 automatic drive shafts
Does anbody know if the drivesafts are the same length for the B16 with automatic transmission as for the manual?
lebarron is offline   Reply With Quote
Old 14-11-2017, 09:40 AM   #2
lebarron
Could really do with some help on this, if any of you guys have the knowledge? if they are the same length, I can order the allspeed driveshafts, which will be much easier
Old 14-11-2017, 11:35 AM   #3
Where do you live ? I can't find reference to a CRX auto being available in UK nor a B series Civic with auto transmission.
If you know the details about the car all I can suggest is to put them in to this site
https://www.lingshondaparts.com/
and compare the driveshaft part numbers with a manual B series transmission and see if they are the same
Old 14-11-2017, 11:40 AM   #4
lebarron
I am in the England, in Kent. I looked on there but again cannot find the CRX b16 auto listed, although they definitely made one, as I have just bought one
Its a Japanese import SIR B16 vtec automatic
Old 14-11-2017, 02:32 PM   #5
I'm presuming it is a CRX Del Sol ?
That's the only AT reference I can find with a B16 engine attached to it in Japan
Old 14-11-2017, 02:39 PM   #6
A quick bit of research on http://jp-carparts.com/ seems to show CRX Del Sol (92-95) SI-R B16 Auto Driveshafts and B16 Manual Driveshafts both seem to have the same part numbers (LH=44010-SR3-JO3 , RH=44010-SR3-JO5)
DISCLAIMER - please check this yourself before committing to a purchase from Allspeed !
Old 14-11-2017, 02:51 PM   #7
lebarron
Good bit of research, thanks.
I've just had a look on there, they seem to list about 12 different part numbers for the driveshaft, even when selecting the exact model, so its hard to say really.
Old 14-11-2017, 03:43 PM   #8
If you're unsure then as you have the donor you could mock up a set of shafts using the CRX shafts and the Mini shafts to get the lengths about right then speak to Allspeed and see if they can say whether their shafts will work. Worse case if they don't you can get your mocked up shafts sleeved and welded and effectively make your own.
http://www.16vminiclub.com/showthread.php?t=36547
Old 14-11-2017, 03:46 PM   #9
You could also try PMing Hayling-Mini who built the one in my previous link, he might remember if he used Allspeed shafts. I believe he still checks in once in a while on the forum
Old 27-12-2017, 08:54 AM   #10
Emily Koon
maxspeedingrods, this site has coilovers, turbo, connecting rods, air suspension, air bag and other parts, they are having sales now
Emily Koon is offline   Reply With Quote
Old 28-12-2017, 09:27 AM   #11
Shaun, your friend been back, the only thing she talks is bananas
Old 28-12-2017, 01:53 PM   #12
yar,wants flicking off into the dog doo,daa, named him as a woman to get away with it, lol
