Old 18-10-2017, 07:14 PM   #1
remington_winchester
Default #ProjectTracy. SOHC D-series mini
delete
remington_winchester is offline   Reply With Quote
Old 18-10-2017, 07:18 PM   #2
Current Issue of clearance. One thought is to cut the backside and weld in flat plate. Any suggestions to clear the clutch master? This is only an issue because of LHD.
Old 18-10-2017, 07:53 PM   #3
None of your pictures show as you are using photobucket
Old 18-10-2017, 08:20 PM   #4
Thanks for the heads up
Old 29-11-2017, 08:25 PM   #5
meetthespeakers
meetthespeakers's Avatar
CC: D16
ECU: Chipped
So, you gonna post a build thread or what Austin?
meetthespeakers is offline   Reply With Quote
Old 30-11-2017, 03:24 PM   #6
See http://www.16vminiclub.com/showthrea...obucket&page=5
We can reinstate your original post so you can add the PB hack described in the thread I've given the link to if you want us to ?
We can also move the post to the Build threads for you ?
