Old 28-09-2017, 01:05 PM   #1
ochumi
Default About gianni potenza subframe
I want to ask you about the subframe... i dont know if its neccesary the reinforcement that i show youn on pictures because for example i can't unbolt the nut of the distribution polley and also i think that i will have the same problem taken out the gearbox...
What do you think?
ochumi is offline   Reply With Quote
Old 29-09-2017, 03:00 AM   #2
it looks like that cross bar that is in the way is part of the strength!
it was put there as a afterthought. by a design person that dont work on any mini car
1> top engine mount follows down from top to help it not twist,
1,A i have seen them be ok and not brake, lots use that system in images i have seen!
2>rose joint connector at front end of tiebar, if i see image correctly,
2,A in my opinion that is very bad design!! looks like rosejoint is held just by one side without support on both sides, so the part in the way gives support!
it looks to run through a small tube with long bolt that may act as a lever against the frame!!
this is my opinion by image you provide!!
Old 11-10-2017, 09:37 PM   #3
Kam
Kam's Avatar
Unfortunately all custom frames will tick some boxes and not others
With the Allspeed frame you can unbolt but not remove the gearbox with the engine in place, it just swings around in there, after all the trouble you end up taking the engine out anyway
Same with the Watsons, its close but it won't pull out so whole lot comes out
Its nice the OEM cars can remove the gearboxes separate but our cars are anything but so its expected - annoying but expected
For the pulley bolt, any chance you can put a jack underneath and loosen the other mounts to able to drop it down or lift it up (without stressing the other mounts too much) to get to the bolt? Maybe send an email to the developer to ask how they do it - if they do
Old 12-10-2017, 01:44 PM   #4
filski
Kam, im in epic need of you moving all you images and updating your build thread finally got around doing mine had a look at yours and photobucket is gone
Old 10-11-2017, 01:10 AM   #5
Kam
Kam's Avatar
Hello mate, long time no speak
You wasn't anywhere near the barrow boy pub on that night was you?
I deleted my PB account a few weeks just before it all went a bit pete tong on forums, not sure if it was hacked or what not but I got rid of, had enough of PB anyway
Unfortunately I don't have time to update the diary on here and other forums its on but I'm actually starting up a new build (non mini) so will need a new hosting site anyway as I would like to put it on here. If there is any particiular picture you need from the old one let me know and I'll upload it
