Old 02-09-2006, 05:44 PM   #31
Wouter
Send a message via MSN to Wouter
Good news: the engine is hanging in the subframe, in the enginebay! yeehaa, I've got it done. (yes, I know I'm only half way) As the digital camera is charging currently, pictures will be available tomorrow.
Now I'm going to continue with the JF (www.velde.co.uk/mini/jf.htm). This topic is going to be quiet for a while until I have that mini is ready for it's paintjob.
Cheers,
Wouter
check my honda-mini site: http://www.velde.co.uk/mini/mexico.htm#mexiconda
Wouter is offline   Reply With Quote
Old 03-09-2006, 09:12 PM   #32
Wouter
Here are some pictures, more info and pics on my site www.velde.co.uk/mini/mexico.htm#392006
@Strudel: see the last two imgs how I solved the front engine mount.
Cheers,
Wouter
Old 04-09-2006, 12:06 AM   #33
strudel
strudel's Avatar
Looks like you are geting closer to the end objective. In my test fits I have the engine tilted forward a bit more like in the doner car. Is the bottom of your oil pan even with the ground. It will most likely work OK in your set up and that is why you can use the oem mount bracket.
I think because I tilted it more forward it hits the grille area and I didn't like that. In the end I will probably make a custom mount. It will not be that difficult and I may even make it out of aluminum. JS
Austin Mini Van with DOHC Honda HP
http://www.angelfire.com/droid/strudel
Honda reliability and power combined with Mini cachet and style.
strudel is offline   Reply With Quote
Old 04-09-2006, 03:56 PM   #34
Wouter
Hi,
it is almost even to the ground. I can't go any further back as the towers are in the way and I need space for exhaust. I'm not using a flipfront, so that's an extra barrier
Cheers,
Wouter
Old 10-09-2006, 08:35 PM   #35
olsson_richard
Send a message via MSN to olsson_richard
Hi Wouter
That is gonna be tight! You could make the section infront of the exuast manifold (The thing that you´ve cut away) removable if that helps. A friend of mine did that on his mini. It looked pretty neat! Keep up the good work!
/Richard
Honda Powered Mini, Sweden
olsson_richard is offline   Reply With Quote
