Old 23-07-2009, 05:06 PM   #16
Pete_H
Pete_H's Avatar
CC: 1333
ECU: megasquirt
Send a message via MSN to Pete_H
Those mk1 ones look good! Do I get those clear lenses on my car?
My suzuki build diary
http://www.16vminiclub.com/forums/showthread.php?t=4427
Pete_H is offline   Reply With Quote
Old 23-07-2009, 07:33 PM   #17
MiniMadGreg.
MiniMadGreg.'s Avatar
ECU: P28 Neptune rtp
Send a message via MSN to MiniMadGreg. Send a message via Yahoo to MiniMadGreg.
They all look very good and well made, you will sell loads of them i think.
MiniMadGreg. is offline   Reply With Quote
Old 24-07-2009, 06:05 PM   #18
2lrMiniVan
ECU: weber alpha tbs
got a van rear lamp u can borrow if u still want
2lrMiniVan is offline   Reply With Quote
Old 24-07-2009, 06:36 PM   #19
Spiyda
Please pm'd
Old 24-07-2009, 07:17 PM   #20
Dowz
Dowz's Avatar
CC: 1590
Send a message via AIM to Dowz Send a message via MSN to Dowz Send a message via Yahoo to Dowz
These you great, well done. will you be putting the mk1 lights on your ebay site or how do i buy. One quick question how do the tail lights change to stop light, do they go brighter as i carn't see any extra leds.
Dowz is offline   Reply With Quote
Old 24-07-2009, 07:35 PM   #21
Spiyda
The LEDs for the stop / tail are the same, when just the tail lights, the power of the LEDs is reduced to about 1/4 , when the Brake lights come on, they go to full power..
I'm doing a few final soak tests at the moment.. testing in high ambient temperature, and at higher than normal voltage... and I'll be putting them on my website when I'm 100% happy. (Oh and water splash tests too )
I already tested the later ones.. I've put one of the prototypes on eBay to see what interest there is..
lots of visits and lots of watchers !
Old 09-08-2009, 01:47 PM   #22
Spiyda
I've now had these on soak test for a while and Im happy they are going to be reliable.
If anyone wants some of the first batch let me know in a pm
I'll be putting them on my website when I get time
I have lights to fit all models now
MK1 (oval angled lens) (40)
Mk1 Van (Oval flatter lens) (40)
MK II (Rectangular no reversing light) (40)
MK III on (Rectangular with reversing light can be supplied with two reversing lights or one reversing light and one foglight) (60)
Full set, both sides...ballast resistors for indicators included
all plus 5 postage per order
Old 18-08-2009, 04:05 PM   #23
Spiyda
Finished soak testing the MK1 Van version ..
Old 18-08-2009, 10:22 PM   #24
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
They are lovely, is the price for a pair or a piece?
//marcus
Old 18-08-2009, 11:40 PM   #25
Spiyda
//marcus
Full set, both sides with ballast resistors for indicators... !
and also a little tube of dielecric grease !
Chris
Old 19-08-2009, 02:46 AM   #26
Red Riley
Red Riley's Avatar
All models? What about these?
Red Riley is offline   Reply With Quote
Old 19-08-2009, 11:14 AM   #27
Spiyda
Well,
It's not a mini, but I could make a set for it if I had light unit for a couple of days..
Old 19-08-2009, 11:39 AM   #28
Marcus Nordblom
ECU: 40mm mikuni rs
I have a set for mine + high brake light to!
Sporting this kind of rear lamps, mk2?
http://img179.imageshack.us/img179/7585/img0875bh7.jpg
Old 19-08-2009, 12:15 PM   #29
Red Riley
Red Riley's Avatar
Well,
Oh, so you're on THAT side of the argument! Just joking! Most people who don't know call it a Mini and I have to explain the whole Mini-Elf-Hornet relationship. Then when I open the bonnet and show them the SOHC VTEC, they get really confused.
The problem with the Elf lights is that the lenses attach to the bezel with tabs at the rear and don't come off like the Mini's. Plus nobody does any reproduction lenses or clear ones, so they're getting increasingly rare. I've thought about cutting a set up to do an LED panel, but probably the simplest thing is just to use the LED replacement "bulbs".
Old 19-08-2009, 12:36 PM   #30
Spiyda
Marcus,
added a picture of the MK2 ..to the posting below
this uses the two of the same boards as the MKIII and later
I will be putting them all on my website in the next day or two
(promised Pete I'd replace the outer sills on the mini by the weekend)
Chris
