Old 09-07-2009, 06:29 PM   #1
Spiyda
Default LED rear lights
I can't seem to find the original thread, but a bit of an update..
I now have a patent filing date so I can move forward!
pretty much all the parts are now sourced, production jigs made etc...
so just into final tweaking..
If we make it to Mini Showdown, I'll bring the prototypes along.. for a bit of constructive critisism (bearing in mind they are prototypes) before making the first batch next week
If anyone is strongly interested, let me know as the first batch will be a limited number.. several sets are already spoken for.
Won't be there in Pete's mini I'm afraid.. reasons in the build thread..
http://www.16vminiclub.com/forums/showthread.php?t=4427
Old 12-07-2009, 12:45 AM   #2
Spiyda
First Picture of the inside of the Mini MK IV version..
available with Fog or reversing light in the bottom
they have the maximum size circuit board possible in the space
Mirror chrome faced circuit board
Plug in to standard socket so in the very unlikely event of failure, just plug the bulb back in!
each has 6 by 0.5 Watt Wide angle LEDs
Thats the same output as about 30 of the small LEDs !
The only fiddling is that if you have an old style flasher unit, you will need to fit a ballast resistor onto the indicator wire on the back of the lamp cluster
(I can supply these too)
Can't wait to see them in either of the two types of clear Jewel type lenses !
Going to buy both types just to see !
versions for other models in the pipeline....
Old 12-07-2009, 03:21 PM   #3
terryg
terryg's Avatar
ECU: rover MGF
very nice . how much ?
The hole MGF in my mini lol. now on a diet
terryg is offline   Reply With Quote
Old 12-07-2009, 06:10 PM   #4
Spiyda
At the moment, for group members, 10 per bulb replacement..
thats 60 a complete set for MK IV
or 40 a complete set for the earlier ones.. (not yet quite ready)
includes dielectric grease for the bulb holders..
includes ballast resistors for the indicators.
+ post and packing at 5
I'll be listing them on eBay and my website at 12 per bulb replacement.
The price is only likely to reduce if we sell enough to warrant having them made by machine, they are very much hand crafted..
I think that compares favourably with the Mini Mania ones (MK1 only)
Old 13-07-2009, 02:00 PM   #5
Spiyda
I've just modified the design slightly by lengthening the threaded support pillar by a few mm
the MK IV version will now also fit the MK II and III llamp units as well !
Old 13-07-2009, 10:15 PM   #6
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
I loke the look of these. Do the MkII ones come without the reverse light as I'm running a Lucas rear spot
Cheers - John
Old 13-07-2009, 10:38 PM   #7
Spiyda
Cheers - John
The MKIIs will be the same boards as the top two on the MK IV eg no Reverse or Fog..
so 4 units at 10 = 40
+ 5 post and packing within UK
dielectric grease, ballast resistors and connectors for the ballast resistors included.
I took a picture of a MKII with the lens on, but very tricky with a cheap compact digital
Old 22-07-2009, 03:02 PM   #8
Spiyda
Just about finished the MK1 Van version,
still looking for the temporary loan of a MK1 saloon lamp cluster so I can design the boards for it.. anyone ?
Old 22-07-2009, 04:22 PM   #9
2lrMiniVan
ECU: weber alpha tbs
hi i got a van rear lamp cluster u can borrow
2lrMiniVan is offline   Reply With Quote
Old 22-07-2009, 04:56 PM   #10
Spiyda
Thanks, but Quadra (Mike) already lent me a van one... I've got the circuit board on soak test for that one right now...
its the saloon one I need..
Chris (-=Spiyda=-)
Old 22-07-2009, 05:48 PM   #11
2lrMiniVan
Chris (-=Spiyda=-)
helps if i read the post properly lol
Old 22-07-2009, 06:19 PM   #12
promazine
promazine's Avatar
CC: 1.8vvc
ECU: Tweaked mems3
Is this the one you need??
If so, i can post you the unit - the lens is cracked so ive got to take it off anyway..
promazine is offline   Reply With Quote
Old 22-07-2009, 07:05 PM   #13
Spiyda
HA HA !!!
I'm the one thats wrong ! (as usual!)
Its the van one I need,
Quadra sent me the saloon one ! which I thought was a van one.. !
so it's definitely the Van one I need to complete the set...
so actually, I'm testing the saloon one at the moment ! pics later tonight I think...
Chris
Old 23-07-2009, 12:38 AM   #14
Spiyda
MK 1 version now complete.. just need the van one to be a complete set !
again the lights overpower the camera, so I reduced the voltage to reduce the brightness so that I could get a picture...
They show a round ring of 6 LEDs when viewed from directly behind... (the aluminium seperatot has been removed.. its not needed with the LEDs)
Same LEDs as the other type,
6 off 0.5 watt wide angle LEDs per bulb
Price is the same, 10 per bulb replacement + p&p (for club members)
= 40 + 5 p&p UK or 10 p&p rest of world
dielectric grease, ballast resistors and connectors included
Old 23-07-2009, 01:25 PM   #15
Spiyda
Bought a pair of the Bolton Mini clear lenses...
Can't describe how cool the combination is... !
I imagine the Ultra lenses are the same but more so...
Tried a video with the power of the LEDs turned right down, but it doesn't really do it justice.. !
