Old 05-12-2018, 06:36 AM   #556
Brakes are plumbed in. Only need to be bled. hurray \o/
There's even a generous 2mm gap between the cork and bonnet. Not even a close fit
edit: might be a stupid question but should i put jubilee clips on vacuum hoses to servo? It's a silicone hose.
Old 06-12-2018, 09:54 PM   #557
paulrockliffe
Looks really cool, what's the headlining material?
paulrockliffe is offline   Reply With Quote
Old 07-12-2018, 05:41 AM   #558
Thanks. It's the same acoustic foam with self adhesive that you can get from ebay.
Old 17-12-2018, 06:31 AM   #559
Findings from the oil sump. Aww pineapple.
Old 18-12-2018, 08:57 AM   #560
DVO
DVO's Avatar
ECU: Chipped
Main bearing or what is left of it?
DVO is offline   Reply With Quote
Old 18-12-2018, 10:33 AM   #561
Don't know yet. I'll need to take the bearings apart to find out.
Old 26-12-2018, 08:44 PM   #562
I took the crank bearings apart and didn't find where those small parts could be from. Will replace the bearings but it'll be a "fun" task to do while the crank is in place.. Crank's surface looked and felt smooth enough.
While I'm at it, I'll change the cam belt too as there's a small crack.
I test fitted the air filter I bought. It's so tight fit that it can only be fitted when the turbo isn't attached to the manifold so some modifications to the alternator bracket are needed.
Oil pan is now fitted with a 16mm tube for the oil return from the turbo.
Old 26-12-2018, 11:26 PM   #563
Hope you get it sorted with no future Issues nice work!
Old 27-12-2018, 12:58 PM   #564
Did you check the thrust bearings on #3 journal ?
Old 27-12-2018, 01:59 PM   #565
Well, those bearings are in place. Timing side one is a bit loose though.
Old 27-12-2018, 03:25 PM   #566
I think that they are held in place by the main bearing cap, so you may be able to roll them out without removing the crank. Worth taking a look if you can.
Good Luck
Old 27-12-2018, 06:53 PM   #567
Good Luck
The timing belt side might roll out but the other most likely not. Will need to check when I get the oil pump out and gain more space.
Old 28-12-2018, 09:17 PM   #568
Made more space for the air filter. I just hope that it flows enough..
Old 02-01-2019, 04:11 PM   #569
This is a bit off topic, but in your post #497, how did you attach the magnets for the speed sensor?
Old 02-01-2019, 06:50 PM   #570
I put a small drop of superglue under the magnets to keep them from moving around on the dummy shaft.
