Old 11-09-2012, 10:20 PM   #496
Richard
Richard's Avatar
ECU: Emerald
The black wrinkle dash looks great Marcus, I used it on our Midget dash and as you say heat is the answer.
BTW the view from your garden is amazing, are those rocky cliffs on the coastline?
R
Richard is offline   Reply With Quote
Old 12-09-2012, 07:22 AM   #497
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
here is some pics, i live to the right in the first pic (you can see the garage if you look closely) and the cliffs you see richard is to the left, (mainland)
the island i live on is separated by a 100m or so channel, outside the island there is a big archipelago with bare granit islands - nice to go out with the boat sunbathing, fishing, surfing etc
40969_1600776503128_8103120_n by G13B, on Flickr
338998_2763469490811_550136945_o by G13B, on Flickr
323242_4323041318047_382414154_o by G13B, on Flickr
Old 12-09-2012, 04:50 PM   #498
DVO
DVO's Avatar
ECU: Chipped
Seen worse places to live
Dennis
Old 10-11-2012, 06:26 PM   #499
Marcus Nordblom
ECU: 40mm mikuni rs
enjoy!
bild by G13B, on Flickr
Old 10-11-2012, 07:49 PM   #500
kcchan
kcchan's Avatar
Looks great, its a toss up between keeping mine yellow as it was originally or grey.
Suck, Squeeze, Bang, Blow.
Old 10-11-2012, 08:21 PM   #501
Marcus Nordblom
ECU: 40mm mikuni rs
as i remember it i bought a typical grey color, this is more greenish grey…
maybe not the color i had choosen from a chart, but hey i think it looks nice and
fruity with the black accents
had some problems with "craters" in the color and some dust too(due to massive 2 days of sanding…) must have been some silicone traces in some spots, used plenty of thinner will flat it down and hope for the best when i do the second coat, the paint looks spray painted and are very easy too use, smells menthol as a bonus
Old 10-11-2012, 09:06 PM   #502
Purtsi
Purtsi's Avatar
Looks great but doesn't the paint add too much weight?
I have a cunning plan...
Old 10-11-2012, 09:15 PM   #503
Marcus Nordblom
ECU: 40mm mikuni rs
2 kg
any mini news from finland then?
Old 10-11-2012, 09:23 PM   #504
Purtsi
Purtsi's Avatar
Only 2kg? No filler then? =)
Nothing special from Finland. I've done some minor improvements to the brakes (new 6mm washers) and put the brake pipes inside a metal tube to protect them from ground hits. So nothing interesting to report oh one thing, I'm going to get a honda short shifter and install that and see how it works.
Old 10-11-2012, 09:30 PM   #505
Marcus Nordblom
ECU: 40mm mikuni rs
Good to hear purtsi, why not brake lines in car?
I will run fuel line inside the car to, nothing on the underside
- roads in my area are very bad, real shell scrapers
Old 10-11-2012, 09:37 PM   #506
Purtsi
Purtsi's Avatar
because I'm too lazy (cheap) to buy new lines/hoses and run those in the car maybe in the distant future...
Old 11-11-2012, 08:48 AM   #507
Aubrey_Boy
Colour looks really good Marcus, one of many that keep going round in my head
I don't envy your garage / workshop or your location at all
Old 11-11-2012, 12:39 PM   #508
Marcus Nordblom
ECU: 40mm mikuni rs
cheers,
itīs RAL 7038 agate grey, will top it with a black roof
(have o roll of carbon vinyl that i will try on the roof too)
Old 12-11-2012, 11:29 PM   #509
Marcus Nordblom
ECU: 40mm mikuni rs
double coat paint system, roller expands during use and after maybe 15
minutes itīsītime for a new one, pretty amasing to see the paint "stretch"
i painted the hole car inside out with one tin (about 2 hour job or so), had
some dust flying around in the garage after 2 days of sanding…so need to flatten down the paint very slightly before next coat
image by G13B, on Flickr
excellerator pedal, (someone was curious how it looked more in the flesh)
image_2 by G13B, on Flickr
and a featherlight accelerator cable with all the right brackets allready there
Basic hot rod electrical system
mc gill suede steering wheel with china quick release
for a small side project
image_3 by G13B, on Flickr
Old 13-11-2012, 07:30 AM   #510
Purtsi
Purtsi's Avatar
So you painted your Mini with a roller and a brush?? Nice new shiny parts btw.
