Old 05-08-2018, 02:38 PM   #1
Default cordless power tools
My cordless drill, impact gun and angle grinder are on their last legs and pretty outdated technology (i got them second hand 15 years ago!) so i need some replacements, the ryobi range looks pretty good as does the dewalt stuff, i don't need anything too fancy as it's just for working on the mini and diy stuff. I need a drill/driver (hammer function would be useful), angle grinder and ratchet (preferably the right angle type like an electric version of an air ratchet). with the possibility to add to the range in the future (so common batteries etc). Any recommendations/brands to avoid?
Old 05-08-2018, 02:52 PM   #2
Drill/impact driver I bought Makita on recommendation of builder friend. Top kit in my experience and with an adapter I use with an impact socket set. Only regret is I was tempted by a cheap ni-cad kit. Definitely get lithium ion - lighter to handle and better life
Old 05-08-2018, 05:33 PM   #3
Iíve been on the tools for nearly 20 years.
Most of my drills are Bosch blue(not the green DIY stuff), Iíve used Makita and Dewalt including the newer stuff when Iíve pinched workmates drills in the past and theyíre certainly not as nice as my Bosch.
The Bosch impact driver I have also has 1/2Ē square end so is handy for wheel nuts and will undo the crank pulley nut on a K with a fully charged battery!
Having said that, the Ryobi One stuff is great value and decent quality for the price it is, we have a few garden tools from that range and I really canít fault it.
Old 05-08-2018, 09:16 PM   #4
l_jonez
ECU: Megasquirt and ITB's
Makita gets my vote, can't fault them. My 1/2"impact driver takes a absolute battering most days of the week. I've always been disappointed with DeWalt etc.
Have a look at what brand the tool hire companies use as they need reliable tools that will be abused
Old 06-08-2018, 06:18 AM   #5
Doodling
Buy the best you can afford.
Iíve used Bosch for years. Just got the angle grinder and canít fault it.
Ryobi in my opinion are ok for basic diy but I still wouldnít expect them to last.
Having used most makes (makita, dewalt, Panasonic and Bosch) there also around the same.
Doodling is offline   Reply With Quote
Old 06-08-2018, 02:15 PM   #6
stun538
We use Milwaukee kit at work and it takes a hell of a battering. Can't fault it at all, quite pricey though
stun538 is offline   Reply With Quote
Old 09-08-2018, 12:11 PM   #7
madrallysport
madrallysport's Avatar
CC: .
Second for Milwaukee, worth every penny
madrallysport is offline   Reply With Quote
Old 09-08-2018, 04:14 PM   #8
I only have a small budget so decided to try the ryobi stuff, so far got the drill/driver and the angle grinder, seem pretty good - the grinder made short work of cutting through an exhaust so should be plenty good enough for the amount of use they will get at home. they are definitely an improvement over my old stuff. I also went for the ryobi as they seem to have the biggest range of cordless tools that all use the same batteries
Old 09-08-2018, 09:03 PM   #9
Iím impressed with the new Ryobi stuff, the old stuff used to be heavy and just average quality but the newer stuff seems much nicer.
I think itís perfect for gear that isnít going to be used and abused everyday, itíll see you many years of service Iím sure.
Old 03-01-2019, 11:36 PM   #10
minion
minion's Avatar
ECU: mems 3
ryobi one + for hard diy ,,cant fault price
heavy abuse on site its dewalt all the way
minion is offline   Reply With Quote
Old 04-01-2019, 08:43 AM   #11
Has anyone ever seen a 90 degree cordless ratchet ? I see plenty of air ratchets like that but never a cordless version, only the usual impact guns which, as I found when trying to strip the rear diff off the CRV wouldn't go in anywhere, it's as if the clearances around it were done to allow a 90 air ratchet, I even struggled with a normal ratchet as the bolts were tight/seized so a 90 degree cordless ratchet would have been a God send (luckily I had just enough room to get a breaker bar in on the bolts)
Old 04-01-2019, 08:54 AM   #12
Iíve seen 90 degree cordless screwdrivers but not impact so I doubt theyíd have the guts to undo things like your diff bolts.
Old 04-01-2019, 08:56 AM   #13
Ryobi RAD1801M ONE+ Angle Drill, 18 V (Body Only) https://www.amazon.co.uk/dp/B006XBU0..._k-XlCbNX4YF89
Old 04-01-2019, 09:03 AM   #14
In my searches I have found some 90 degree impact wrenches but theyíre low voltage (12v) and have maximum torque of 45nm, there was a Milwaukee one that did 75nm but itís £200 for the body only!
Old 04-01-2019, 09:31 AM   #15
Yeah, that's pretty much what I found. Surely if a 90 air tool can do big torque then I don't see why a motor and battery can't be put on to the guts of one of these rather that just making weak ones that aren't worth buying.
