Old 05-12-2011, 04:08 AM   #1
longlivekel
Default Which Brakes best with vtec?
Hey guys.
I have a D series home made frame with my stock mpi brake setup and suspension...
I am thinking of upgrading my brakes. I don't think they are cutting it.
I have the stock 8.4" non vented dual piston brakes with brake booster.
I am thinking of upgrading to 4 pot piston with vented rotors.
What do you guys have / use / or think is best?
And yes.. I did do a search on the forum. Poopy results and gave up after lookin for 45 minutes...
longlivekel is offline   Reply With Quote
Old 05-12-2011, 06:26 AM   #2
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
metro vented 4 pistons. i first used normal 8.4 mini's, and warped 2 sets in about 2 months. i switched over to the metro's, and they stop tons better.
Old 05-12-2011, 11:21 AM   #3
monkey
monkey's Avatar
ECU: A box of chips
And don't ever buy green stuff pads for roads driving. Takes ages to warm up and brake properly
Old 05-12-2011, 02:20 PM   #4
Freebies
Freebies's Avatar
CC: D15B
ECU: MTD Frame, not MTB
I purchased the Minisport brake kit (calipers, rotors and pads), the vented and grooved type. Can't say how they do as the build isn't over. They look awsome. Hope the work as much as they look.
The calipers colors option are cool and give a nice touch to any " pimped " mini. They use regular brake disc lines, no need to get the Metro Line kit with the jumper and banjo.
Freebies is offline   Reply With Quote
Old 05-12-2011, 02:56 PM   #5
longlivekel
There is a vented 8.4 setup out there that uses the standard non vented hubs correct?
Old 05-12-2011, 03:04 PM   #6
Freebies
Freebies's Avatar
CC: D15B
Minisport kit uses regular hubs, flanges and CV joints (disc type of course...)
Old 05-12-2011, 03:18 PM   #7
Kam
Kam's Avatar
I'm running minispares 4 pots for 8.4" solid discs and carbon metallic pads and no bias, stops b16 fine unless you stamp on the pedal then its brown trouser moment
Old 05-12-2011, 06:26 PM   #8
Aidstap
Aidstap's Avatar
I'm using 7.9" discs and fiesta callipers not had any problems with them, going to be fitting 10" wheels some time in the near future I hope, but at the moment I run them under my 13x7 wheels.
Aidstap is offline   Reply With Quote
Old 05-12-2011, 06:43 PM   #9
longlivekel
I am just in toss up on upgrading to vented brakes. Just not sure if i want 8.4 or 9.5.
The 9.5" doesnt look too difficult to convert. Maybe make my own spacer. Depends if i can get the adapter kit cheaper than have it made at a machine shop.
I am just tired of non vented and how frequent they warp or form hot spots.
Old 05-12-2011, 07:07 PM   #10
daveyjones
Hmmm...brakes what they for then????
daveyjones is offline   Reply With Quote
Old 05-12-2011, 07:49 PM   #11
longlivekel
I am just saying that non vented mini brakes are not so great.
From experience...
Maybe i should just use my emergency brake from now.. haha
Old 05-12-2011, 08:07 PM   #12
Dave Potter
Dave Potter's Avatar
Hello friends,
So what about the rover metro 100 type calipers, is their a better caliper to replace these? Does anybody know the piston size of the fiesta ones, or the rover ones for that matter?
I currently run .625 master cylinder, rover calipers, 6:1 pedal ratio with a bias bar and Mintex M1144 pads. Stops ok but still feels a bit "wooden" and like it needs a smaller master cylinder or larger piston calipers. Or more ratio on the pedal, it's a bit of a minefield!
Would be soooo nice to be able to lock the fronts without so much effort!
regards, Dave
Dave Potter is offline   Reply With Quote
Old 06-12-2011, 06:13 AM   #13
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
locking the fronts with little effort isnt a good thing..
Old 06-12-2011, 09:32 AM   #14
Brumski
ECU: Mini Tec uprated Honda
I second this... I run this setup on my A series 16v van (140BHP) and have never suffered from brake fade to the point of danger even when caning it on track. And that's with standard (non-vented) disks and standard pads. Using grooved disks and decent pads would make it much better too.
Mind you, I only used this setup due to wanting 10" reverse rims on the van.
Old 06-12-2011, 09:52 AM   #15
Originally Posted by Dave Potter View Post
Hello friends,
Dave
Are you using the Metro GTi / MGF calipers and 240mm vented discs ?
They work well with the standard Mini servo system provided you use good aftermarket pads.
fynnbar is online now   Reply With Quote
