Old 14-11-2011, 05:42 PM   #16
billing5
billing5's Avatar
CC: 1500
ECU: cbr carbs
Send a message via Yahoo to billing5
thanks for the comments guys
willp, i am as shocked as you mate, went in expecting much lower numbers than that!!! as you say just imagine s300 some goodies and a good tune
i am unsure of the diameter of the skunk intake hole on the manifold, may be on the website i will have a look, but its running the stock c4 throttle body at the moment thinking of giving it a polish, knife edge the butterfly and port match to the skunk.
thinking of keeping my c4 exhaust manifold too, but doing some porting work on it were it joins the head as the welds are lumpy and protrude into the port.
dose anyone know if there is any good ceramic coating available on the market that you can apply yourself or would it be best to send it out to be done
billing5 is offline   Reply With Quote
Old 14-11-2011, 06:03 PM   #17
billing5
billing5's Avatar
CC: 1500
ECU: cbr carbs
by the looks of it its 75mm diameter opening but i may have this wrong
Old 14-11-2011, 09:42 PM   #18
Mintegra
Mintegra's Avatar
ECU: JDM OBD2
Ah, brill thanks...Im guessing the C4 TB will be about 62mm...
C
It's so much easier to build on the computer!!!....
My Build Diary
Old 14-11-2011, 11:28 PM   #19
Kam
Kam's Avatar
If the skunk2 inlet hasn't been machined then the hole is 64mm
The max you can machine these out to is 75mm
Old 15-11-2011, 06:13 AM   #20
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
Originally Posted by Mintegra View Post
Ah, brill thanks...Im guessing the C4 TB will be about 65mm...
C
im pretty sure its only 58mm. it may be 60, but no bigger than 60
Old 15-11-2011, 08:21 AM   #21
Mintegra
Mintegra's Avatar
ECU: JDM OBD2
Ah right... the information on these is a little misleading... cos some say upto 75mm but that provided you machine them out!...
So its only the type r with 62 inlet... so in order the fit a larger TB to any of these manifolds they would need machining??
My Build Diary
Old 15-11-2011, 01:53 PM   #22
k20/k24 allmotor
k20/k24 allmotor's Avatar
CC: 1998.2
ECU: honda stock
The s2000 one is 64mm and I got one lol.
Old 15-11-2011, 10:13 PM   #23
daveyjones
dose anyone know if there is any good ceramic coating available on the market that you can apply yourself or would it be best to send it out to be done [/QUOTE]
Give Marcote Ltd a ring in Lichfield http://www.marcote.co.uk/
Marks the man in the know...
they specialize in coatings of all descriptions. Teflon based non stick may be better if you will be on the colder side of the engine i.e intakes. Ceramic can be applied or zircon based may be better which takes temperatures of 1725 deg c on exhausts.
daveyjones is offline   Reply With Quote
Old 16-11-2011, 01:14 AM   #24
Kam
Kam's Avatar
Which size are you needing? the one for the TB or for the inlet?
The standard b16a2 TB is 60mm and the standard b16a2 inlet is 62mm, not sure on the c4 inlet but yeah the c6 TB is 62mm so the inlet must be the same as the skunk2 at 64mm
If your machining out the standard TB then you would need to check the max you can go, I know on the inlet side of things with the skunk2 you can't pass 75mm, not that in an ideal world for a road car you would need to machine out this big........
I'm using a 68mm TB and my skunk2 inlet has been machined out to 68.5mm, so whatever you choose make sure the inlet side has 0.5 or 1mm larger than your TB
Handy little reference
Old 16-11-2011, 08:27 AM   #25
Mintegra
Mintegra's Avatar
ECU: JDM OBD2
Thats very useful Kam... answers my question. cheers
My Build Diary
Old 16-11-2011, 06:49 PM   #26
billing5
billing5's Avatar
CC: 1500
ECU: cbr carbs
just another quick vid showing my exhaust manifold
Old 16-11-2011, 10:47 PM   #27
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
nice. i never thought to look at my header while mine was rolling. mmmm.. maybee next time.
Old 16-11-2011, 11:50 PM   #28
Kam
Kam's Avatar
'kin disco lights! Do people still say disco?
I'd still say mine was more hotter
