#1 |
Hi guys, what’s the best advice you can give me regarding engine preparation for painting silver, I see lots of you have done this, my engine is mucky & oily in places, I don’t have enough air capacity to use a shot plaster, what good ways do people find best for removing the old crud before painting, I’ve etch primer and engine paint.
#2 |
My current head was covered in grease and crud, I stripped it down and the guy that did my head work left it in the parts cleaner for a while before having it ultrasonic cleaned, cane up like new!
However, if your not going to strip it down, then a GOOD pressure washer, followed by a good soaking with engine degreaser, followed by another pressure washing works well, don’t buy cheap degreaser though, it’s false economy, I quite like a degreaser by Chemical Guys, it’s made very light work of the oil spray underneath my car from an oil leak. Sent from my iPhone using Tapatalk |
#3 |
If you clean it up enough then I wouldn’t bother with paint, however if you do decide to paint it, don’t bother with VHT paint, it’ll just flake off and look rubbish in a month.
#4 |
Thanks for the info guys, definitely going to power wash it degrease it, I will check out the chemical guys, I have seen that vht paint but never used it, I was once told if you etch prime a engine block first then any paint will work, that’s why people have stated to colour code there engines the same colour as there car.
I called into Helmsley steam engine rally today, picked up some de-buring tools to go on the end of a drill, I’ve not seen these before there rather smooth, not like the harsh ones. I will have a play with these later on & see what the results are like ![]() |
#5 |
I just saturated my block with degreaser and scrubbed it with a small wire brush, then more degreaser followed by an air dry. When dry, I then used metholated spirits and a rag to wipe it all down till the rag remained clean, then painted.
I used VHT silver engine paint without primer, and 2 years later its still there. |
#6 |
Cheers for that, I’ve not thought about methylated spirits I’m thinking it’s going to take about 10-15 hours from start to finish, so I will start this week at the evenings whilst the weathers good cheers
#7 |
Before
#8 |
![]() ![]() Sent from my iPhone using Tapatalk |
#9 |
#10 |
#11 |
slowly getting there
#12 |
looks good pal.
#13 |
#14 |
#15 |
Think I might do the rocker cover black, I know everyone goes for red, I might add a bit of red somewhere
Thread Tools | |
Display Modes | |
