Old 05-07-2018, 01:44 AM   #1
benvvc
benvvc's Avatar
Default Brakes????
I'm running Watson's frame on my vvc mini so mgf brakes upfront. No servo and a yellow tag master cylinder. Looking for suggestions to improve as they are shocking. I've bled them but no better. Can't get them to lock up . Feel as though there is no braking until your nearly touching the floor but even then there isn't much force to them. What are you guys/girls using? Cheers Ben
Old 05-07-2018, 06:02 AM   #2
A used to have a yellow tag with standard Mini 8.4” 2 pots, drilled discs and green stuff pads that used to stop me fine.
All I have done since is upgrade to MiniSport 4 pots and that was only to go vented and stop the brake fade when I was being a bit silly.
Must be something wrong with your setup if it’s not stopping you, a lot of people think they’ve bled the brakes but find they’ve not bled them enough.
Have you got the front and rear lines connected correctly?
What rear cylinders are you using?
What calipers and pads are you using?
Old 05-07-2018, 07:40 AM   #3
I'm using mgf calipers and discs and I'm going to be adding a remote servo.
I don't have that much pedal movement though its just really hard work, but I'm also not sure I could lock them up in the dry.
The same brakes on my tf with the factory servo are still not overly sharp but they do stop the car.
Is it an issue with the master cylinder?
Old 05-07-2018, 08:00 AM   #4
If you've got excessive pedal movement then there is an issue.
I know you've bled them but there could still be some air trapped somewhere, usually bubbles gather on a high point like the top of a loop or even where a pipe that goes straight actually has a slight incline on it before turning down. What method do you use for bleeding ? Ezi-Bleeds are great but they push a constant pressure through so its possible that the fluid is not pushing the bubbles out. My dad still swears by the two-person method where one pumps the pedal whilst the other opens and closes the bleed nipple as he says by giving a sharp down pump on the pedal is creates a sudden push on the fluid which would dislodge any bubbles trapped in high spots. Give a good number of pumps per wheel as the air might be trapped much further up the pipe so would take a while to find its way along the pipe through the caliper and out of the nipple so don't assume a few pumps of clean fluid means there is no air.
Also get someone to press the pedal hard and check for bulging rubber pipes, I had an issue with an old Clubbie Estate, I'd fitted new brakes and hoses as part of a refresh but one of the new hoses perished whilst still in the garage and I noticed the brakes were spongy and tracked it down to a hose that had perished and the hose was bulging under pressure.
Old 05-07-2018, 08:31 AM   #5
I have the same setup as you and had the same problem with a lot of travel in the pedal and couldn't lock the brakes up, it turned out that the new yellow tag master cylinder's have the front and rear outlets the opposite way round than the older ones. After changing the pipes round they now work how they should, I've also fitted drilled and grooved disc's with Mintex 1144 pads, these need a bit more effort when cold but after a couple of miles driving or a few good presses of the brakes then the stopping power is a lot better than standard.
Old 05-07-2018, 08:44 AM   #6
It certainly sounds more like trapped air or a fluid leak if there’s a lot of pedal travel.
A fluid leak will be obvious, you’ll be losing fluid!
As I said earlier, a lot of people there no they have bled the brakes only to find there’s still air in the system, there’s been a few threads recently where people have gone away and re-bled and come back and said they found a huge air bubble.
As Oz mentioned, if you have access to an extra person then the that method is always best, otherwise an eezi-bleed is a nice bit of kit for working by yourself, that’s what I usually use when my wife’s pretending to be busy!
Old 05-07-2018, 09:21 AM   #7
Haz
Same brakes same problem here. I do get a solid pedal on a 2nd pump though.
I've bled mine 3 times now using the 2 person method. I'm wodering if it's something on the drums as I've had the issue since replacing all my brakes from mini 8.4s and standard drums to MGF at the front and minifins on the back.
Could it be something to do with that weird square section pryamid adjuster thingymabob on the drums?
Old 05-07-2018, 12:42 PM   #8
benvvc
benvvc's Avatar
Cheers for the replies guys. I'm using mgf calipers vented discs and standard pads and standard mini drums at the back. I've used the easy bleed system a couple of times with no difference in outcome. The pedal does get firmer if I pump it but has no greater braking force. Il try the 2 person bleed at the weekend If I get time. It doesn't pull either side under braking. Just feels like it isn't going to stop lol
Old 05-07-2018, 01:04 PM   #9
Can you confirm you have checked the cylinders of both calipers and the rear slaves actually work when the pedal is pressed? You need to remove the caliper to do this and remove rear drum. With the caliper off, check the carrier sliders. These sieze up and cause problems.
Next, as Keith suggested, check the pipework. Too many get the front to rear mixed up.
Not sure if this is possible with these calipers but seen it on other cars (Inc classic Mini's), are the calipers on the correct side? The bleed screw should be at top of caliper.
If all this is correct and bled properly, the pedal should move no more than an inch before working.
Are you using the standard bias valve? I found this caused too much braking at the rear. I swapped it for a Willwood adjustable one.
Fitting braided hoses helps reduce brake pedal travel. I also have these on mine.
I have the standard Mintex road pads and shoes. Brakes are great. No servo required, even on track.
Old 05-07-2018, 01:56 PM   #10
Haz
I've not checked my cylinders but they were brand spanking new calipers. Rears were working fine days before.
Calliper nipples facing upwards.
Braided/solid lines all around. EBC greenstuff pads, EBC drilled & grooved vented discs, EBC shoes on rear.
Yellow tag master, no servo, unknown aftermarket bias valve (also used on previous system).
I'm going to bleed it again at the weekend with more aggresive pedal actuation as suggested. I think it's something else though, I know what air in the system feels like and this isn't it.
Old 05-07-2018, 02:29 PM   #11
It still sounds like air in the system to me, you’ll be having to pump the brake because a vacuum caused by air in the system is drawing the caliper piston/pistons back in.
Old 05-07-2018, 05:11 PM   #12
benvvc
benvvc's Avatar
I've got the help of my uncle at the weekend so will check fronts and rears bleed them and retest. And report back
Old 05-07-2018, 06:02 PM   #13
Try bleeding the master cylinder first by undoing a brake pipe union. Just keep the fluid off the paint.
Old 06-07-2018, 12:30 PM   #14
Drain all fluid out of system totally, it's not exspenceive!
Get some dot4 synthetic , I'm not debating fluids hear!!
Some front pads that are available, are next to USELESS!!
block the back brake pipes off totally somehow and try that?
Old 06-07-2018, 01:10 PM   #15
By DOT4 you meant DOT5.1 right?
But I’m not debating fluids here either!!
