Old 01-07-2018, 05:54 PM   #1
Zeemax Power
Send a message via MSN to Zeemax Power
Default Honda b16 A2 clutch
Hard clutch to push down, kept it Honda with spacer. Any thoughts on why it's hard compress. Easy fix? If I used ap would make it easier?
If it breaks build a faster one!
Zeemax Power is offline   Reply With Quote
Old 02-07-2018, 12:27 PM   #2
mikko
mikko's Avatar
ECU: obd0
Smaller bore master is needed, I went half inch but people say 14mm works too.
Old 03-07-2018, 07:31 AM   #3
Mini-khaos
ECU: Spoon ecu vtec 5,100 - 9,000
Yeah I went with the 14mm one. Honda one was to hard and bery poppy
Mini-khaos is offline   Reply With Quote
Old 03-07-2018, 05:21 PM   #4
hebby
where did you purchase the 14mm master from guys ?
hebby is offline   Reply With Quote
