Old 28-06-2018, 06:59 PM   #1
Default Want a good screw with nipple,
Bike carbs have a awkward throttle cable joiner in middle,
It's a clever system once in place,
What did you use?
I used to be able to buy a round lug with a tiny screw with hole for cable ,,the bosh,
Went in 2 motor bike shops but they didn't have a clue,
Unless I want a bike cable off the shelf it's no good for them,
Where have all the motor engineers gone?
Old 28-06-2018, 07:05 PM   #2
Shaun, when I read the title, thought you were on the wrong kind of site for that!
Can you not get something similar to the cable clamp on the throttle/choke cables on the SU type carb?
Or something like this?
https://www.ebay.co.uk/itm/Connectin...YAAOSwkNZUgdXz
Old 28-06-2018, 07:24 PM   #3
The e,bay link is close, I could have robed a s,u clamp but
Not near them and wanted to bolt on tonight,
And seems I want to connect the peach while carbs are in my hand, as it's long way down if the mongs are bolted on
Old 28-06-2018, 08:08 PM   #4
mm man
Solderless nipples like the eBay link but you can get them a lot cheaper. Used on all lambretta and Vespa scooters plus more Search classic scooter solderless nipples .
Also seen chocolate blocks used but with the plastic cover removed .
Old 28-06-2018, 09:47 PM   #5
Solderless niples, yes that's the ones,
I discovered them on lambretas years ago,
There's a nice choice when I looked for them,
Now to find out close size as it swivels
Can't get in to measure orifice so looks like I have to undo,box them, opp,s
