Old 23-05-2018, 04:51 PM   #1
Rhys-89
CC: 1.6
ECU: Will be standard to begin with
Default Changing clocks b18c4 civic mb6 clocks to s2000 clocks
Hi all after l2b this weekend I seen a set of s2000 clocks used on a vtec. If I buy the s2000 clocks with wiring do I just need to id the wiring on the s2000 clocks and convert from the civic clocks or do the civic clocks wiring plugs fit straight in.? Also would I need any engine sensors for these s2000 clocks as there digital speedo or is it just buy the s2000 clocks and convert with what I currently have ? Thanks all.
Squirt,squeeze,bang,blow!
Rhys-89 is offline   Reply With Quote
Old 23-05-2018, 06:08 PM   #2
loud_sam
loud_sam's Avatar
Looked in to doing this my self you can get a conversion loom from wireworxs but it's about 300 quid. There is a DIY thread I found I will try and find it and post the link they do look good tho.
Sent from my HTC U11 using Tapatalk
loud_sam is offline   Reply With Quote
Old 23-05-2018, 10:25 PM   #3
Rhys-89
CC: 1.6
Thanks I have no issues working wiring out just wondered if everything works as it should without the need of different sensors engine wise to run the speedo.
Old 25-05-2018, 10:08 PM   #4
Aidstap
Aidstap's Avatar
Wiring guide https://honda-tech.com/forums/hybrid...guide-1570344/
You need something like healtech speedo healer to get the speed reading right and modifry convertor to get the temp gauge working and then something so get the fuel gauge reading right.
Aidstap is offline   Reply With Quote
Old 26-05-2018, 07:36 AM   #5
andyfkettle
andyfkettle's Avatar
Got s2000 clocks on my d series. As above Speeo healer required and modifry unit for coolant temp. I used an s2000 fuel sender in the mini tank. Was surprisingly easy to fit.
Old 29-05-2018, 12:52 PM   #6
Rhys-89
CC: 1.6
I'll be getting a new fuel cell made I currently have a vdo dip tube sender in my current fuel cell. The s2000 clocks I have bought have come with a whiteford davies converter hopefully this will have in it what's required to change speedo and temp gauge ? If not where to go or what to buy would be great or where to get it thanks
Old 30-05-2018, 07:22 AM   #7
Haz
Heh! Whiteford-davies! I know him, he works at my place, small world!
If you have any issues with the kit I could probably put you in contact with him. He's a good dude.
Old 31-05-2018, 10:03 PM   #8
Aidstap
Aidstap's Avatar
Temp gauge convertor http://www.modifry.com/index.php?rou...ory&path=18_59
Healtech Speedo healer https://www.healtech-electronics.com/products/sh/
Spiyda fuel wizard https://www.spiyda.com/fuel-gauge-wizard-mk3.html
I have the speedo healer already and the clocks but never got around to buying the other 2 bits so can't guarantee that they will all work but they should.
Old 10-06-2018, 03:31 PM   #9
Rhys-89
CC: 1.6
Thanks sorry only just checked back hear I have since bought the speedo healer and modifry chip. I haven't fitted this yet but watching clips on YouTube i haven't seen anyone mention the fuel gauge .y clocks showed full when full but I have since removed tank so should in theory read empty until my new tank arrives. Thanks for the links
Old 11-06-2018, 05:31 AM   #10
andyfkettle
S2000 fuel sender bolted to mini bracket.
Old 11-06-2018, 09:39 AM   #11
Rhys-89
CC: 1.6
Nice one. I ha e a vdo dip tube in a baffled tank turning up this week hopefully. My s2000 clocks did read when on my vdo dip tube in another type of fuel cell. So hopefully the new one will.
