Old 15-05-2018, 11:56 AM   #1
Default Watson's tracking settings?
Just a quick one, what angle, (degrees & minuets) have people had there tracking set too? (I know this is dependent on peoples set up) Mine is Watsons subframe, mgtf red band rack, Watsons springs & Spax adjustable shocks, have you set it to the classic mini or mgf? After having a look around last night on a couple of mg sites the setting that came out most for the mgf was +5 minuets each side, I realise this is different than what the manufacture setting is 0 deg +/-6 minuets. I've had mine set too +5 minuets and it has made the steering a lighter than when I first had it set to mini settings of 0 deg -5 minuets so a slight toe in, this was slightly heavier than what it is now.
Thanks in advance
Old 15-05-2018, 01:17 PM   #2
I set mine to 0 deg as per the Metro standard settings
Old 15-05-2018, 02:57 PM   #3
Yeah that's pretty much the same as what the mgf settings are.
Old 15-05-2018, 06:46 PM   #4
Me too
