Old 15-05-2018, 07:22 AM   #1
andyMac
Default Engine bay Fusebox & relay options
what have people bought / found for 'nice looking' fuse and relay boxes for the engine bay to replace the chunky black plastic box standard ones..?
I'm after some ideas of what looks good. Not too worried about the in car fusebox as that'll be hidden anyway.
I've got a B16A2 from a 97 Del Sol wiring loom and fuseboxes etc..
Any pics or links?
andyMac is offline   Reply With Quote
Old 16-05-2018, 01:24 AM   #2
joltfreak
joltfreak's Avatar
ECU: Standard-ish
All of mine is hidden in my mini. Nothing under the bonnet
Old 16-05-2018, 06:18 AM   #3
andyMac
I think thatís the way to go. Everything Iíve seen around seem boxy and a little large for the mini bulkhead area.. even the modular ones.
Old 24-05-2018, 11:37 AM   #4
miniphil30
ECU: Erm none yet
I'd be interested in this also, not even sure how many of the engine fuses in the big black box are still needed?
miniphil30 is offline   Reply With Quote
Old 24-05-2018, 11:59 AM   #5
pompeyal
pompeyal's Avatar
Are you talking about the Honda harness engine bay fuse box?
Thinking about it if that is what you are talking about, I havn't used any of that fuse box, most of it as far as I can remember is for ABS and Auxilary stuff you dont need, have you got a Civic Haynes Manual, you can work it out from there.
I am modifying a complete Honda Civic loom for my project as I am using the Honda steering column and alot of the Honda switches and under dash fuse/relay box, be carefull if this is what you want to do because some of the wiring you may think as redundant may be linked to something you need so dont cut anything out until your are completely sure it is not needed. It has been a while since I touched mine, by the way it is not yet finished, I cant remember where I am with it. I don't need things like sun roof, electric windows heated rear screen but I would like to keep wiring for stereo, clock wipers etc. your needs may be different so take your time and mark up everthing.
Old 24-05-2018, 06:17 PM   #6
Fuses you may need in the engine bay fusebox
Power to ignition switch
Power to light switch
Power to horn
Power to brake light switch
Power to hazards
Power to radio
Power to interior light
Power to PGM-FI main relay
Power to rad fan relay
Power to blower relay
Power to heated rear window relay
Old 28-05-2018, 12:42 PM   #7
Harley
I use a MPI mini 4x maxi blade fuse unit in the engine bay to cope with the big stuff like main power distribution, and normal blade fuses in the car for the rest where they can be hidden out of the way.
