Old 14-05-2018, 02:18 PM   #1
andyMac
Default Wiring again.. B16A2 97 Del sol
Hi everyone.
I've just started a new project.
B16A2 in a roundnose. I got the donor engine and harnesses etc... 3rd hand from a 97 Del Sol.
Usual question as the first thing I want to do is wiring..
Has anyone got wiring diagrams for the above? Apologies as it's been too long since I've done a honda mini and can't remember OBD0/1/2 etc... but I'm sure someone on here knows.
You used to be able to get PDFs online, but old old links seem to have disappeared.. Ideally I'd like the huge diagram thats all on one page for the entire vehicle..
TIA
andyMac is offline   Reply With Quote
Old 14-05-2018, 04:07 PM   #2
https://web.archive.org/web/20160308...ingdiagram.pdf
Here's a start - you'll be a version of OBD2
Old 15-05-2018, 06:41 AM   #3
andyMac
thanks. that's a great starter for 10 and looks far less daunting than I imagined.
Assumption I've made from the link is I could layout my loom as described in the diagram and everything else in the Honda loom is surplus to requirements..??
Does anyone have the original total wiring schematic / diagram?
Old 16-05-2018, 02:05 PM   #4
andyMac
Am I right in thinking that diagram above represents all the wires I need to keep and can strip the loom to just them??
The connector positions for the ECU and wore colours on the engine connectors don’t match, but I’m assuming I can just cross reference them to mine for the equivalent wires?
Old 16-05-2018, 08:09 PM   #5
Yes
Yes
Old 22-05-2018, 06:06 PM   #6
thomsonminis
Has anyone else have problems getting this link to work?
flat oot like a deuks fit!!!
thomsonminis is offline   Reply With Quote
Old 24-05-2018, 11:15 AM   #7
andyMac
Link works fine for me...
Update though on why I had significant mis-matches...
Apparently my loom etc.. is from a 1994 Del sol not a 97... So I'm guessing OBD1
Old 28-05-2018, 08:39 PM   #8
gonk43
gonk43's Avatar
CC: 1.6
ECU: Honda 0BD1
andymac
Be careful with the coolant temp connector. When disconnected, engine will not fire. Had this with my loom in OBD1
gonk43 is offline   Reply With Quote
Old 02-06-2018, 08:51 AM   #9
andyMac
Thanks for that.. I was planning to keep the Honda wiring for the temp sensor so fingers crossed (unless I make one cut too many) I won’t hit that issue, but good to know.
