Old 06-05-2018, 11:26 PM   #1
ochumi
Default recommendation of spring for protech coilover daily use
hi
if somebody can tell me wich combination of front and rear spring i should have to put for a daily use... im using a protech coilver set and lm looking for springs on dfaulknersprings.com
thanks
ochumi is offline   Reply With Quote
Old 07-05-2018, 09:15 AM   #2
Start with 400 lb/in on the front; good luck with the rears.
Which engine / subframe Ochumi ?
Old 08-05-2018, 11:02 PM   #3
ochumi
engine d16a9 subframe giani potenza
now i have this set up but i see high and hard...
1.9" 8" 425lb front each spring
1.9" 9" 150lb rear each spring
the weight on the corners are
211kg 216kg
125kg 110kg
Old 09-05-2018, 07:53 AM   #4
Well if it's high and hard, plus the car is very lightweight, go softer ...
