Go Back   16v Mini Club Forums > General Public Area > General 16v Mini Chat > 16v Mini Videos
Old 10-11-2013, 05:38 AM   #1
Mini-khaos
ECU: Spoon ecu vtec 5,100 - 9,000
Default My first scary drive :)
Months ago! She's off the road getting improved now
http://m.youtube.com/watch?feature=y...e_gdata_player
Mini-khaos is offline   Reply With Quote
Old 29-12-2013, 08:58 AM   #2
Fuzzydicerule
ECU: Standard with S300
Isnt that how it always goes? It looks like she was running well, What are you changing?
Fuzzydicerule is offline   Reply With Quote
Old 29-12-2013, 05:10 PM   #3
Mini-khaos
Ye it runs great! Changing few bits , it's all in the build threat! Looks a lot better an hopefully feels better it's a great driver! Drove it 2000klm in 2 days an didn't miss a beat or hav a problem
Old 16-01-2014, 04:06 AM   #4
Mini-khaos
Can't wait to get this back on d road
Old 18-01-2014, 05:26 PM   #5
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
Is that 11s to 100mph with a b16? If son that's seriously shifting mate, first drives are always fun
miniwade is offline   Reply With Quote
Old 18-01-2014, 08:19 PM   #6
Mini-khaos
Yes! It is, it's a weapon, good eyes and I took it a little handy. It's b16b internals wit s80 wit kaz diff, power is instantaneous cheers dude
Old 30-01-2014, 05:02 AM   #7
Mini-khaos
So a friend of mine said 0-100mph in round 11 seconds isn't fast???? I highly disagreed ! Wat do yous tink
Old 24-03-2014, 06:23 PM   #8
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
If ur using the civic clocks it's more like 70 mph it's calibrated for bigger wheels
However your car does move in a straight general direction have u had it aligned? what spec was it aligned to? I'm planning on getting one professionally done soon
Old 24-03-2014, 07:01 PM   #9
Mini-khaos
As far as I know, it's all done by the ecu so it can't be wrong, just like putting 17,s on a civic, it's not done on rotation it's done by the rpm so it can't be wrong!!!
No the car was a little all over the place, it's faster now and a bit more violent!!! Quite scary wen u put it into2nd gear an put the foot down it just wants to go left, violently ��scary ,,,
I'm going to get a rally/drift pro to set mine up :/ expensive but it won't pull all over the place
Old 24-03-2014, 07:34 PM   #10
Mowen
Mowen's Avatar
CC: B18C
ECU: P30 + Ostrich 2.0 + C R O M E
Is the S80 the box everyone moans about on here? I can't remember which one exactly, but pretty sure it was a type r box....how's it feel mate? Kaz diff ehh out of interest, what FD do you have. Shifting
Mowen is offline   Reply With Quote
Old 24-03-2014, 09:30 PM   #11
Mully
Mully's Avatar
Make: Toyota
ECU: greddy
Honda Speedos read high from factory and they have a preset wheel size either 15" or 16" depending on ecu
Mully is offline   Reply With Quote
Old 24-03-2014, 10:48 PM   #12
Kaison
Kaison's Avatar
As said before, ECU is set to read RPM, but it's assumed a set rolling radius of wheels for that RPM, so it will still be wrong even if you change to a different profile tyre and a 15" wheel. . .
It's done on an algorithm with set values, there's no way for it to pluck the value for your rolling radius out of the air.
I only bow under braking.
Old 24-03-2014, 11:34 PM   #13
Mully
Mully's Avatar
Make: Toyota
ECU: greddy
honda boxes have vss in the box its geared off the fd but they are known for over reading nothing to do with rpm
Old 24-03-2014, 11:41 PM   #14
Kaison
Kaison's Avatar
Poor example on my behalf, but the facts still stand, I was trying to simplify.
Geared off the FD, so it's related to your RPM.
It's related to the speed of your output shaft. Your final drive speed is going to be the same with 10" wheels as 17" wheels, but that doesn't mean the wheels will be turning the same rotations per RPM.
Old 25-03-2014, 12:22 AM   #15
Mully
Mully's Avatar
Make: Toyota
ECU: greddy
i get you
only gps speedo arent thrown off my smaller wheels you need a speed healer to fix high reading speedo
