Old 18-02-2018, 11:55 AM   #271
Originally Posted by joakwin View Post
rear brake bracket by joaquinn lopez, on Flickr
here's my 2nd bracket, i made a few changes
i still need to clean it up, its a super ruff cut right now
im probably going to pick up some more 1/2 inch t6160 aluminum on Monday, and cut out another bracket so i wont have to run that 1st one
Yeah, that looks so much better.
Old 19-02-2018, 04:45 PM   #272
joakwin
CC: 1.6
ECU: Bone stock
more brake brackets by joaquinn lopez, on Flickr
Old 19-02-2018, 08:49 PM   #273
joakwin
CC: 1.6
ECU: Bone stock
rear brake bracket left by joaquinn lopez, on Flickr
knocked out another bracket so i dont have to use that 1st one
Old 24-02-2018, 03:05 AM   #274
joakwin
CC: 1.6
ECU: Bone stock
rear control arm by joa kwin, on Flickr
Old 28-02-2018, 12:19 AM   #275
joakwin
CC: 1.6
ECU: Bone stock
lower coilover mount by joa kwin, on Flickr
Old 06-03-2018, 02:04 AM   #276
joakwin
CC: 1.6
ECU: Bone stock
mini wide body by joa kwin, on Flickr
rear arms by joa kwin, on Flickr
Old 09-03-2018, 01:31 AM   #277
joakwin
CC: 1.6
ECU: Bone stock
right rear suspension by joa kwin, on Flickr
right side arms is on now
this weekend i plan to try and get the Honda park brake cables into my car
and i want to paint my calipers black
but my hips are telling me we have some rain coming, so im not sure if im going to work on the car or not
Old 15-03-2018, 04:30 AM   #278
joakwin
CC: 1.6
ECU: Bone stock
rear calipers by joa kwin, on Flickr
changed out rear calipers and pads today
brake system is almost done,
i plan to test drive the car this weekend
Old 15-03-2018, 02:58 PM   #279
bobjonah
bobjonah's Avatar
Interesting rear arms! They look very sturdy - did you make them ? What are the inside flanges for ?
Old 15-03-2018, 04:33 PM   #280
joakwin
CC: 1.6
ECU: Bone stock
the rear suspension started out as a mini tech kit
and then I mod them to make them wider
I put the flat plate onto the arms because I'm thinking about maybe putting
the car on air, and the plate will become the lower air bag mount
the metal they are made out of is 1.25 Dom tube, .120 wall
the arms with hubs weight is 5.8kg each
I never weighed the disc brake set up
I'm still unsure if I want to put this car on air, or air ride on my truck
Old 16-03-2018, 04:46 AM   #281
joakwin
CC: 1.6
ECU: Bone stock
1st drive by joa kwin, on Flickr
test drove the car today
i still need to re work the front suspension to make it wider for the flare kit i plan to go with
click on the picture and the video will play
Old 21-03-2018, 01:34 AM   #282
joakwin
CC: 1.6
ECU: Bone stock
wide body kit 2 by joa kwin, on Flickr
wide body 4 by joa kwin, on Flickr
wide body 3 by joa kwin, on Flickr
mounted the front clip and started to work on the flares
today i changed out the trans cooler lines, move the radiator up 4.5 inches
fixed a hose leak at the iac valve thingy
Old 25-03-2018, 03:24 AM   #283
Arches are FAT BOYS,
Old 25-03-2018, 04:01 AM   #284
joakwin
CC: 1.6
ECU: Bone stock
i got them for free also
Old 25-03-2018, 11:42 AM   #285
Cool vid too, almost sounds like manual
