Old 12-11-2017, 03:24 PM   #91
richie08
richie08's Avatar
ECU: Rover mems
Andy, I have a pg1 flywheel from my vvc here that you can have gratis (just needs posting) - but is that the flywheel you need?
richie08 is offline   Reply With Quote
Old 12-11-2017, 07:10 PM   #92
I'm afraid it's not as simple as that.
It's a rare item! A Landrover Freelander 1.8 petrol one. The fittings and outside dimensions are identical to the one you have. It's manufactured from the same casting with the cast number on it being identical. BUT, it has a bigger clutch (228mm instead of 215mm) fitted to it which I want to accept the extra power.
Thanks for the offer Richie but unfortunately, it's not the one I'm after.
Old 12-11-2017, 07:15 PM   #93
richie08
richie08's Avatar
ECU: Rover mems
No worries, was worth a go just in case
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
