Old 05-06-2013, 10:19 PM   #226
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Well, its been a long time. Been working on the Iroc quite a bit lately (custom brakes, 6 speed trans, etc..)
Started sanding the mini.
Decided not to go with green, saw a mini in green and just plain don't like it.
Think I'm going with redbull colors. Blue body, silver roof & hood stripes. Maybe some red pin stripes. Should look really good when done.
What do yall think?
Old 05-06-2013, 11:29 PM   #227
Drummingjason
Drummingjason's Avatar
That should look good! I am going with a similar look (Subaru blue pearl with white roof and stripes). I guess you could say Yamaha colors.
Drummingjason is offline   Reply With Quote
Old 11-07-2013, 04:35 AM   #228
Jeffreypang911
Jeffreypang911's Avatar
I really liked the green with white roof.
But I love themed racing cars. You don't see them anymore (JPS, jagermeister, Gulf), except redbull! So I say go for it!
Edit- As far as your gauge location, I actually pulmed mine inline with the fuel line and used a fittings/clamps. Your way seems better though, but I needed a way to connect the cut hose to the hose going to the steel line underneath anyway.
Jeffreypang911 is offline   Reply With Quote
Old 19-08-2013, 09:46 PM   #229
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Back to solid color! Primer came out real nice which made me happy.
One more once-over with the sand paper and should have him looking good. Going to have the car sprayed once it's sanded as I do not have the proper facilities to paint.
Old 23-08-2013, 04:52 AM   #230
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Ended up getting my FPR and pressure gauge installed. Turned out really nice.
I am going to do comparisons between the stock FPR and the aftermarket to see how they compare a little later on.
Aftermarket FPR, Upgr8, works great so far, no complaints. Bolts right in place of the stocker so no hassle at all.
Old 03-06-2014, 03:15 AM   #231
Drummingjason
Keoman, did you ever get your car painted?
Old 14-07-2014, 11:36 PM   #232
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Sorry long time no updates. Been working on the Camaro quite a bit.
Mini is not painted yet, but I finally ended up getting the guts to chop the front off on Saturday.
It is now time to get some long needed engine work done, timing belt, recoat valve cover, oil pan gasket, and the LS transmission I put together will be going in also.
Heres the damage
Old 14-07-2014, 11:40 PM   #233
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Decided to ditch the fuel cell also, even though it is pretty. I am a function over fashion person so the usable aspect of trunk space (as little as it actually is) is enticing to me.
Ended up getting a stock 7.5 gal tank and making it bigger Bought two -6 steel fittings and welded a supply and return to the tank and voila.
Not as good as TurboMini's welds but it'll hold
Old 15-07-2014, 12:06 AM   #234
Drummingjason
Looking good! Keep it up.
Old 03-10-2016, 08:53 PM   #235
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Well its been a long time with no updates.
Ended up painting the car this weekend. Still have to paint the nose clip, doors, hood & trunk lid
Turned out pretty good for my first paint job
Old 03-10-2016, 08:55 PM   #236
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Old 04-10-2016, 07:49 AM   #237
Those are some seriously wide bonnet stripes !
Old 07-10-2016, 03:49 AM   #238
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Yea
I like em
at first I was going to mask the "normal" mini stripes but those grew on me.
Going to try and paint the rest tomorrow.
Old 19-02-2017, 08:11 PM   #239
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Got everything painted and have been working a ton!
ended up having to sand the hood down all the way. Previous paint was effecting the finish badly.
Old 19-02-2017, 08:13 PM   #240
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Also got my "custom" stock fuel tank installed and mounted.
Much better IMO...
