Old 10-08-2018, 03:09 PM   #16
Please donít suggest banded steels, thatís my thing!
Old 10-08-2018, 09:20 PM   #17
Coaster
ECU: None yet
After talking on PM with Colin he says he's wanting to use the suspension from the TF. I haven't seen that done before.
Also I said it was probably best getting a front subframe from a MG F with steering rack, suspension, hubs and brakes then adding the arms from the rear frame.
He said this isn't what is in the guide. I agree so maybe Gaz could alter that.
Metro wheels are getting hard to find. Maybe getting some steel wheels banded is a good option for a stock look.
Thanks for all the replies so far but all I said was that I have already bought an MGTF rear subframe. I thought it was a bare frame, all those I looked at on ebay were bare. When I picked it up, it had the complete suspension set up including the coil over units but no rack or brakes/hubs etc. All the engine support brackets were attached, I do not want to run gas units, nor do I want to use thos very short springs, I was intending using coil over units, not necessarily the ones that came with my subframe, I was just wanting to know what parts I would need and I believe that question has been answered. I was thinking of after market wheels, I'm not overly keen on the metro alloys and definitely wouldn't want steels.
Anyone selling any of the bits I need? if not Im off to ebay
Colin
Coaster is offline   Reply With Quote
Old 11-08-2018, 08:14 AM   #18
I think the problem you will have with the tf frame is the towers that the coil overs fit into are taller and will foul the bulkhead. Also I would advise against using the rear top arm arrangement with a front hub & wishbone as it is not designed to take the longitudinal loads the front hub will put on it (it's fine on the rear as the rear hub arrangement dissapates these loads through the lower arms etc)
Old 12-08-2018, 09:49 PM   #19
Coaster
ECU: None yet
Originally Posted by gazwad View Post
I ...................o I would advise against using the rear top arm arrangement with a front hub & wishbone as it is not designed to take the longitudinal loads the front hub will put on it (it's fine on the rear as the rear hub arrangement dissapates these loads through the lower arms etc)
I don't follow, do you mean the lower suspension arm? the top arm looks identical to the metro (I did say looks). the lower arm would definitely need changing for the metro lower wishbone A shaped one.
Having had a measure up I can see the issue with the taller turrets fouling the ends of the bulkhead crossmember, some height reduction with the angle grinder will be called for.
Old 13-08-2018, 06:50 AM   #20
No, the top arm, although there are two different types - some are like the mgf/metro ones (T shaped with a bend to clear the coilover with 2 bushes/bearings for the top arm pin) some are different with a shorter part which houses the bush for the top arm pin - so only have one bush for the pin. If you have the type with 2 bushes/bearings then these are fine to use on the front.
Old 13-08-2018, 11:46 AM   #21
Coaster
ECU: None yet
Thanks for that, cant tell from the photos I took of the subframe and wont get a chance to check for a week or so.
Colin
Old 13-08-2018, 02:27 PM   #22
https://rimmerbros.com/Item--i-GRID018903
Front TF Top Arm
https://rimmerbros.com/Item--i-GRID018914
Rear TF Top Arm
Old 13-08-2018, 11:12 PM   #23
Coaster
ECU: None yet
Thanks Oz
Old 16-09-2018, 11:58 AM   #24
Coaster
ECU: None yet
I now have in my garage an engine which was advertised as a 1.8 120 from an MG ZR. It came fitted with a Getrag gear box which I am hearing was only fitted to smaller engines....that makes me suspicious as to the size of the engine, either it has had an engine change at some time or the seller has sold me a pup The raised section to the right near the flywheel doesn't appear to have any numbers on it Are there any other ways to identify capacity?
Colin
Old 16-09-2018, 12:19 PM   #25
Can you post a picture up to show us the gearbox?
Unfortunately if the engine number is missing then I can think of an easy way to identify it without having the head off, thereís a good chance a bore scope wonít help identify the pistons as theyíll be too dirty.
Does the area where the engine number should be look like itís been ground back?
Old 16-09-2018, 12:38 PM   #26
If you can take a plug off and accurately measure the stroke, then the 1.8 was the only engine with a longer stroke.
Old 16-09-2018, 02:46 PM   #27
Coaster
ECU: None yet
I couldn't see a number but took a picture anyway and looking at the photo I can make out 18K 4FF 04 599898...I think so all is well I hope.
The gearbox is definitely a Getrag Ford item, this is cast into the casing. I believe these had a 3.7 final drive which would be ok with my 13" wheels. As for not being strong enough, this is going into a very light GRP bodied mini marcos body shell so will be far less stressed than hauling a steel bodied car around. Still leave st question of what drive shafts do I need, special ones or are they the same as the PG1?
Colin
PS, I'll upload some pics to Flicker and post them on here later
Old 16-09-2018, 03:36 PM   #28
Youíve got a 1.8, I doubt the spline count for a Getrag gearbox will be the same as a PG1, I canít answer that question.
You will also need to figure out if you have the Getrag from the ZT or if itís an IB5 which was made by Getrag also and has Getrag stamped into the casing.
Old 16-09-2018, 04:00 PM   #29
Coaster
ECU: None yet
A few google searches turned up that the MG ZR 1.4 and 1.6 was fitted with the IB5 Getrag Ford box from 2003, my guess is that it has had the 1.87 motor added later.
Not sure what size wheels a ZR had as standard but this gearbox has 25 D 3.62 printed on a paper label with barcodes on it, I'm hoping the 3.62 is the final drive ratio. Drive shafts seem quite elusive on ebay so far
Old 03-10-2018, 11:53 PM   #30
Coaster
ECU: None yet
The 15th photo is captioned (bulkhead box required to clear gear linkages). Could anyone expand on this? does it apply to the pg1 gearbox, cable or rod type linkages?approx. dimensions. I'm nowhere near getting the engine and frame installed so have no clear idea of this or any other clearance issues. My car is GRP and I'm on with some other GRP repair work on the bulkhead at the moment so would be nice to sort this issue at the samw time whilst its still relativrly warm
