Old 20-09-2018, 11:56 AM   #1
nerdymind
nerdymind's Avatar
CC: B16
Default Arches
Hi there,
I want to change my arches which is now the miliga ones and am running 13x7 wheels
Any suggestions for other arches? With pics f could
File Type: jpg 9CFDD21D-9689-47BC-9ED9-9D0443DB674A.jpg (157 Bytes, 187 views)
Thank you
Ayman
nerdymind is offline   Reply With Quote
Old 20-09-2018, 02:57 PM   #2
Could you be more specific with size? A dimension from the top of the front arch to outer edge of tyre is usually preferred.
I am using group 5 arches which give a old skool look but are 75mm wide.
Old 31-12-2018, 12:09 PM   #3
nerdymind
nerdymind's Avatar
CC: B16
are u using that with 13 inchs wheels?
Thank you
Ayman
Old 31-12-2018, 04:04 PM   #4
Yes I am.
Old 02-01-2019, 09:43 AM   #5
nerdymind
nerdymind's Avatar
CC: B16
can i have some photos of that please
Thank you
Ayman
Old 03-01-2019, 10:10 AM   #6
Old 06-01-2019, 08:21 AM   #7
nerdymind
nerdymind's Avatar
CC: B16
Yes this is better the miliga arches which i cant handle anymore
Thank you
Ayman
