Old 17-09-2018, 04:25 PM   #1
Default Aerodynamic improvements
http://carbonweezel.co.uk/testing/testing_mini.html
I have to say I have a bit of an interest in aero dynamics (on a novice/superficial level) and found the above link really interesting reading.
Taking this as a basic (and having no real qualifications in fluid dynamics etc) I was wondering whether there could be anything to be taken from the above link that could be applied to a road-going Mini.
Here's my ideas, I'd be interested to hear peoples thought:-
1) under bonnet - I think the positive lift measured at the front of a Mini is largely due to the enormous grill area gobbling up huge amounts of air that can't go anywhere forcing it to go under the car (a bad thing). Racers vent their A-panels but it ain't pretty, usually a few round holes.
Thoughts to reduce the lift. Firstly blank off part of the grill to restrict air being ingested. With a 16v Mini we tend to have a front mounted rad in front of the gearbox so this needs to be open. Engine will need cooling so some air will need to get in just to try and replace the hot under bonnet air.
The air going in to the grill has to go some where. Going under the car is a bad thing so firstly the subframe needs a belly pan to cut the air going under the car. Wheel arch liners will help air getting dragging in or out of the wheel arch and will channel air to back of wheel well. Controlling this air needs some thought and I think channelling it as smoothly as possible down along the doors would reduce drag if hot turbulent air just being expelled out of holes in the A-panel so a duct would be needed behind the wheel arch to turn the air and direct it down the side of the car.
It might also be worth adding a duct of sorts behind the rad to channel the hot air directly to the wheel well rather than just in to the engine bay.
2) Reverse air flow at base of screen - According to that link the old trick of raising the bonnet doesn't let the hot air as the base of the screen causes the air to try and flow back along the bonnet. ERA knew this and the bonnet "vent" on the trailing edge of the bonnet is not to let hot air out but to take advantage of this reverse flow and draw cool air directly on to the plenum and turbo. My thoughts is could a similar "vent" this be used to draw cold air to an air filter box under the bonnet ?
3) Under body air flow - Generally the rule seems to be to stop as much air from going under the car as possible. Short of running the car dropped to the weeds a discreet front splitter would help separate the air and minimise the amount going under the car. This could be integrated into the belly pan mentioned above.
I'm not one for body kits but I could be persuaded that a discrete but functional side skirt could be worth fitting. to stop air being sucked under the sides of the car.
The undersides of the car are quite uneven so perhaps a sort of flat floor either side of the Transmission tunnel could be matched to the front belly pan and the side skirts. Small returns on the sides of the flat floor panels should encourage the air to stay under the car also.
The whole rear subframe area seems a total mess in aero dynamic terms and so panelling off the lower parts of the subframe to smooth out the area should help. A centre exit exhaust would assist in keeping things flowing else trying to keep the air controlled around the side exit box would be difficult. I see there are some rear diffusers for classic Minis on the market and something like this from TDK should integrate well with a centre exit exhaust
Again tying this in to a flat floor would really help smooth out the air travelling under the car
Those are my thoughts for a complete aero package for a classic Mini - probably overkill for a road car and more applicable for a road-going trackday car.
What are peoples thoughts on the above ?
Old 18-09-2018, 01:36 AM   #2
Shit Oz , you have just arrived at the wrong diparture lounge
I think that 150 hp just forses the lump though it air regardless,ok I think if it was as matter of a average 120 mph lap time it may help to think about it,
Old 18-09-2018, 06:18 AM   #3
all the extra weight of those aero mods would probably cancel out any benefits for most road minis and even trackday cars. only worth it on an all out race car in my opinion. Time/money would be better spent on making the car lighter and some driver tuition for trackdays to get the most out of what you already have
Old 18-09-2018, 12:06 PM   #4
Haz
ECU: Hondata S300
^agreed with Gazwad on that one.
That said, I'd have guessed the biggest improvements would be from the flat(er) floor (including engine undertray) and tie in the rear valance.
.... or a roof chop?
Old 18-09-2018, 02:52 PM   #5
Personally I think the under bonnet venting through the A-panels and not under the car and restricting the amount of air getting in through the grill in the first place would be the most important of the things mentioned as this reduces the natural lift at the front of the Mini. The Underfloor smoothing doesn't add "downforce" but it just reduces drag by minimising the turbulence under the car.
One other thing I read was what on first glance seems counter-intuitive but actually makes sense, is to have an aperture smaller than your rad to duct air into the rad. It would seem that maybe grabbing as much air as possible and forcing it in to the rad would give better cooling but what actually happens is that the rad is a big restriction and as air will always take the path of least resistance it will find somewhere else to go. By creating a smaller aperture the air entering it spreads out in to area between the aperture and the rad and as the area is greater behind the aperture than in front of it the air slows down and spreads out and that helps the air to go through the rad more effectively ! Obviously you need to effect a sort of seal from the rest of the engine bay else the air would still just bleed around the rad instead of going through.
Old 19-09-2018, 04:14 AM   #6
Haz
ECU: Hondata S300
True, that makes sense. If you block most of the grille you're going to get a build up of heat from the engine and manifold which will sap power unless you have a cold air feed to your intake. I don't know how much of an effect on water and oil temps that would have either... I know mine's boarderline in hot weather with an ally rad and 12" fan.
Old 19-09-2018, 07:40 AM   #7
That's where venting the A-panels comes in, as long as the flow through the grill is less than the A-panel vents can dispose of then you can keep a flow of cold air going through the engine bay to help keep under bonnet temps down, along with heat wrapping or ceramic coating the exhaust manifold. That's the theory anyway.
As for induction temps, yes cool air is good and ducting cold air to some form of filter/airbox is preferable, hence my querying whether the reverse flow at the base of the windscreen could be utilised to feed cold air in to the back of the engine bay around the TB
Old 19-09-2018, 09:43 PM   #8
Starmag
You wanna get yourself this book... race car aerodynamics by Joseph Katz full of lots of useful information.
It's difficult with a mini because it is basically a brick with wheels, but improvements can made. Another bonus with making it more aero other than better handing is improved mpg
Starmag is offline   Reply With Quote
Old 19-09-2018, 11:20 PM   #9
If it makes you happy then it should be supported ! It matters to you even if it makes no sence to me ,
I love the use of free air under the windshield for engine supply, it's semi, contradictory but that doesn't matter,
