Old 02-09-2016, 12:04 PM   #376
the flood gates are open!!
put a main live direct to starter pole, have a seprat battery and earth it to car wiv jump lead, turn egnition on so lightes are on,
start starter direct by the direct thick live, or pull it on a rope,
Old 02-09-2016, 12:14 PM   #377
Shit, 2 posts running at once,
Old 15-01-2017, 04:00 PM   #378
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Default NudgerSS 1.6 16v
Just so you know I've not totally given up on this, I bought this a few months back.
Not done owt with it of course but it's there for when I can be peachd.
Sent from my D5503 using Tapatalk
Old 16-01-2017, 12:01 AM   #379
i can tell your a serfice grinder,
i worked with your kind before, dreaming about a ford capri lol
Old 16-01-2017, 08:08 AM   #380
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
It's just a dream Shaun. The better half would not be pleased.
Old 16-01-2017, 12:14 PM   #381
she smart
Old 16-01-2017, 11:05 PM   #382
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
So even though it's not running and probably won't be for a while, I saw this and ooh shiny...
Much nicer than the great ugly yellow thing that Vauxhall supply.
Old 11-02-2017, 06:34 PM   #383
Hoggy
What you doing with your current ECU Nudgerss when you fit the emerald?
If it's for sale I would be interested. It's a small block Vaux conversion I have too.
Hoggy is offline   Reply With Quote
Old 11-02-2017, 06:47 PM   #384
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Make me an offer mate. Got the full professionally made loom to go with it too.
Old 12-07-2017, 07:44 PM   #385
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Went and had a poke around the wiring tonight and came across something strange. I found that my injectors have got 12v going to them all the time...even with the key out of the car!
If I earth one pin of the injector without the ignition on then the injector will fire but if I put the ignition on it and try to earth it then it won't fire. Not sure if its the main 5 pin power relay that's gone shonky. Not got another one to try. Bizarrely, if I remove the main relay then everything still works, even the ECU. Serious gremlins in this jumble of wires methinks.
Old 12-07-2017, 08:14 PM   #386
Reminds me of an old car I had when I was younger, can't remember if it was an XR2 or a Cavalier but you used to be able to turn the headlights on and bump start it without the keys!
Old 12-07-2017, 08:31 PM   #387
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Lol sounds about right Dan. Wouldn't mind actually if I could bump it.
Old 13-07-2017, 07:37 PM   #388
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
When you've had months of head scratching, change a relay and it fires straight up.
Should've been delighted but I managed to expel swear words I'd forgotten about
https://youtu.be/4WZeQw-jC3c
Old 31-12-2017, 02:11 PM   #389
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Popped into the garage to fire both cars up. Pleased to say the Mini fired up straight away and ran well
https://www.flickr.com/gp/152108708@N03/280H65
https://www.flickr.com/gp/152108708@N03/72AUr5
Old 31-12-2017, 02:35 PM   #390
boom boom, sumers on its way, meet up and lots of man huggs
