Old 04-11-2019, 08:43 AM   #1
ilmung
ilmung's Avatar
ECU: standard with +- 130 hp
Default engine angle G13B
I know that the engine of a suzuki is angled at +- 15 -20 .
I have +- 7-10 , so normally the oil will stay a little more backwards with the possibility that the oilpump would not take the oil correctly ?
Would this be a problem of lubrification or not ???
ilmung is offline   Reply With Quote
Old 04-11-2019, 10:45 AM   #2
My engine sits almost flat and has been working OK for the past 10 years (fingers crossed). Just make sure there's enough oil in the engine.
Old 05-11-2019, 06:02 PM   #3
ilmung
ilmung's Avatar
Default angle engine G13B
Hi thanks for the info !
If it was ok for 10 years , I think it will be ok for another 10 years
Old 07-11-2019, 10:05 PM   #4
KMG
CC: 1293
I have a very small angle on both my conversions and I've never had a problem.
After that,if I was going anywhere,I was running.
KMG is offline   Reply With Quote
Old 08-11-2019, 01:25 PM   #5
ilmung
ilmung's Avatar
Thanks all for the info !
Old 10-11-2019, 01:52 PM   #6
Only issue will be your oil sump will be sticking out a lot.
This is why I have cut mine to make it less angle.
Only lost 250cc capacity.
Good.
Old 12-11-2019, 10:07 PM   #7
ilmung
ilmung's Avatar
Thanks Atchi for the info !
