Old 17-04-2018, 09:36 AM   #61
Old 17-04-2018, 11:00 AM   #62
AWD
Originally Posted by GEORDIE SP1 View Post
No going back now
Had a we play with rear frame, almost fitted in. A few issues with it hitting fire wall and front hoop around tunnel sitting to low. Going to redo the front section of frame something closer to AWD frame instead of cutting the fire wall
Attachment 8477
Attachment 8478
inspiration
Old 17-04-2018, 12:30 PM   #63
GEORDIE SP1
GEORDIE SP1's Avatar
Originally Posted by AWD View Post
inspiration
Old 26-04-2018, 09:59 PM   #64
GEORDIE SP1
So phase two, looking a bit more like it,
Being a cheap skate narrowed the top arms and reinforced then
Got a wheel on to set to max low, cut the inner wheel arch to suit and marked coilover position
Just want to tilt nose of diff down slightly and then itís lots of welding.
Old 30-04-2018, 12:04 AM   #65
Good stuff , how did you work out the hight for rear springs?
Old 30-04-2018, 06:07 AM   #66
AWD
nice, its coming together buddy! what coilovers are you using?
Old 30-04-2018, 12:04 PM   #67
GEORDIE SP1
They are AVO coilovers, 12inch by 2.5 springs, plenty of adjustment on them,
So hopefully will be able to get desired ride height ,
Old 03-05-2018, 08:56 PM   #68
GEORDIE SP1
Boot floor mocked up, hopefully get it all welded in over the weekend
Old 12-05-2018, 06:29 PM   #69
GEORDIE SP1
Boot floor, turrets, tunnel and seat pan all sorted,
In process of making up stainless exhaust, alloy tank purchased ,
Just need to measure prop shaft and get it chopped
Old 12-05-2018, 06:36 PM   #70
mikko
mikko's Avatar
ECU: obd0
Nice
Old 12-05-2018, 08:52 PM   #71
Good work!
Old 12-05-2018, 09:11 PM   #72
GEORDIE SP1
Cheers , canít believe were the times gone. Away to the NW200 most of next week, then only 4 weeks to Wales
Some late nights ahead I think
Old 13-05-2018, 02:54 AM   #73
Are you driving it to Wales ?
Old 13-05-2018, 07:48 AM   #74
GEORDIE SP1
Probably not get it Mot in time.
Me and Vfast going to trailer with camper and tent, at least then have somewhere to put the spare wheel
Both cars in pieces at moment
Old 13-05-2018, 09:09 AM   #75
Boom!! Nearly all enters minis are in bits ,
Any chance of any dulse and yellow man and Bally blue
Lol
