Old 15-07-2018, 11:47 AM   #1
lebarron
Default B16a2 automatic in standard round nose
So I set myself the challenge of doing a b16a2 automatic conversion. I can only drive autos since I lost my leg in an accident.
There are a couple that have been done but not a huge amount of info out there.
So I bought a 92 crx, and all speed frame and went for it.
The engine and gearbox definitely doesn't fit due to the size of the gearbox. I ended up chopping the frame to pieces, only really keeping the rear tower mounts and back half of the frame. Had to make new mounts to move the engine a lot further over, you will see from the pics, it sits under the wing quite a way, to get the length of the gearbox in.
It means I will have to make custom lower arms, rear drive shaft mount, and drive shafts, but the engine is now in place in the car. Needs to come out now so I can finish and strengthen the subframe.
Just thought I'd share some pics so far.
lebarron is offline   Reply With Quote
Old 15-07-2018, 12:57 PM   #2
Underhauled
Pics man, where are the pics!!!!!!
Sounds like a different approach. Looking forward to seeing the results.
Underhauled is offline   Reply With Quote
Old 15-07-2018, 02:03 PM   #3
Pics don't show, yet!
Look forward to what you do,
Old 16-07-2018, 10:18 AM   #4
lebarron
Pics above now working
Old 16-07-2018, 05:42 PM   #5
Underhauled
Much better. Looking good.
Old 17-07-2018, 01:07 AM   #6
Smashing it ,
Old 17-08-2018, 04:37 PM   #7
Interesting build, looking forward to further updates.
