Go Back   16v Mini Club Forums > Builds > Other Mini Builds
Old 18-08-2019, 08:16 PM   #166
evenbiggerdave
Happy with that
Dave
evenbiggerdave is offline   Reply With Quote
Old 19-08-2019, 10:22 AM   #167
MattG
Administrator
MattG's Avatar
any more info on bead roller / specs / make /demo ?
Mini Restoration on YouTube
VW camper in storage , Red hot , www.16vmini.co.uk www.jetblackmini.co.uk
Dad's Building K1100 : bmw.16vmini.co.uk , donate to club running costs : paypal@16vminiclub.com
MattG is offline   Reply With Quote
Old 19-08-2019, 12:33 PM   #168
Ronski
CC: 1995
I'd also be interested in that please.
Old 19-08-2019, 07:54 PM   #169
evenbiggerdave
Itís literally £160 off eBay, 6 sets of dies, can do the pattern like I have been (steps, different depths) and ends of pipe like for intercooler hoses, as long as itís over 2Ē as thatís the die sizes.
All I did was beef up the machine with box section as it flexed/twisted a lot!!! Now itís solid!! Can roll 2mm stainless with no twist on the turns!!
Added a longer piece on the clamp down bolt as that had to be done with a spanner. The machine is just as good as a £700 machine now. Well chuffed. These are pics I have on my phone......
To mark out the designs, I just use my steel ruler as the edge width, then same to space the pattern, then use a 30mm socket to draw round for the radiusí!
Hope that helps you guys a bit??
It does distort the steel, as itís stretching it....but you can get majority of the twist out over ya knee! Then when you weld to the frame work itíll pull it straight.
Dave
Old 22-08-2019, 05:50 PM   #170
Ronski
CC: 1995
Thanks, will have to invest in one when I start working on the Mini again.
Old 24-08-2019, 07:57 PM   #171
ECU: MEMS3
Like that a lot. Some sweet welds on the back of that roller as well.
Old 25-08-2019, 09:49 AM   #172
evenbiggerdave
Do buddy, I use it so much more than I thought, even just to put an edge on something. Like if I cut a pice or Rust out, then make a plate, add 5mm ďjoggleĒ around the edge.....(with the roller, like I did my gear stick hole plate) the youíre not butt welding
Old 25-08-2019, 09:51 AM   #173
evenbiggerdave
Thanks man!! It doesnít move at all now. Defo the best mod to do. If you YouTube ďharbour freight bead roller modsĒ, the Americans do loads with cheap tools
Dave
Old 26-08-2019, 08:56 PM   #174
evenbiggerdave
Default Blackbird turbo powered mini
Today I made a new inlet manifold!! Just a load of stainless.....a hole saw.....and my welder! Oh.....and lots of measuring!!!
I have a throttle body off a civic, already has a map sensor, which means I can just buy a 3bar one for my turbo application.
Iím just waiting on my mate to turn me up some bosses for my injectors Iíll weld them in, and a couple off boost take offs and jobs a goodn!!
Well chuffed. And no....it doesnít weigh much!!! Iím not running an intercooler anymore as space is a bit tight. The charge pipe is pretty short, and Iíll have air ducting in, do hopefully itíll be ok. If I have issues, Iíll have to add one! All the bike turbo deals Iíve seen run without.
Here some pics......
Engine is back out now. Iím debating whether to strip the whole thing again now and get all the parts powder coated, or just do a total fit up, make sure it runs, then complete strip down and powder coat, underseal, paint etc Iíll work it out haha
Dave
Old 29-08-2019, 08:10 PM   #175
becko
ECU: Not sure yet
Love the inlet Dave ����
becko is offline   Reply With Quote
Old 29-08-2019, 09:25 PM   #176
evenbiggerdave
Old 29-08-2019, 09:25 PM   #177
evenbiggerdave
Cheers buddy!!! Hopefully itíll work!
Dave
Old 15-09-2019, 08:29 PM   #178
evenbiggerdave
Hi guys.
Couple of updates as been super busy with everything but the mini!
Injector bosses made and welded in, red oxided the rear and welds/bare metal etc. Injector rail on!
Chain on too! It is in line, the pic just makes it look super on the grapes!!
I have rose jointed rod to make a turbo brace, then engine out, frames blasted and powder coated. That way, when I get it running, I only have to drop the subframes complete to get the shell ready for paint
My pump is here, just waiting on the filter, some brackets and some AN fittings to plumb all that in.
Slowly but surely!!
Dave
Old Today, 10:02 AM   #179
Great work
Dopeshow is online now   Reply With Quote
