Old 14-07-2014, 03:46 PM   #1
Alex1380
ECU: Megasquirts
Default Voltage drops
Hi Guys,
I'm loosing voltage from the alternator to the battery and then back to the ecu which i think is messing my tuning up.
Measured at the alternator i get 14.2-14.5v, at the battery this has dropped to 13.5-13.7v then at the ECU the laptop is telling me i'm getting 12.5-13v
Now I've got it wired from the alternator to the starter then from the starter to the battery. The ECU, injectors, coil pack, fuel pump (all the injection related stuff) runs off a good side wire from the battery though a relay which is switched by the ignition.
I was advised to do this so the battery would even out the voltage from the alternator and act as a capacitor.
should state its a megasquirts ECU.
Any ideas?
Alex1380 is offline   Reply With Quote
Old 15-07-2014, 10:55 AM   #2
where does the voltage sensor wire come from ?
Bob Jonah
Old 15-07-2014, 12:19 PM   #3
Alex1380
ECU: Megasquirts
The ecu records the voltage it is receiving which it also logs.
Old 15-07-2014, 12:54 PM   #4
Richspec
not familiar with megasquirt but on other ecu's the ecu acts as the earth signal and the power is supplied from elsewhere, which sounds exactly like you have it?
So I'm failing to see how that is affecting your tuning? what symptoms is it displaying?
You of course could have a bad earth which is why your ecu is showing 12.5 -13?
Mr 'No patience with dumbass newbies who can't use the search function'
XE powered AMT Race frame and Allspeed VTEC Mini builder, (plus some 5 and 8 ports too)
Youtube Channel
Richspec is offline   Reply With Quote
Old 16-07-2014, 10:14 PM   #5
evolotion
evolotion's Avatar
most likely an earthing issue as stated. if you measure the voltage between the body of the alternator and the earth input to the megasquirt and get a reading thats your problem
11.9@118 :)
Denis.
evolotion is offline   Reply With Quote
