Old 10-08-2017, 01:52 PM   #211
Told you, its that hot girl's fault from the training video
Old 14-08-2017, 01:04 PM   #212
Brake calipers on, I've moved the braided line since that was taken. Doing the hard lines tonight
Last bit of the wiring labelled up, I'm only using about a foot of the original Allegro loom from the indicator / wiper stalks.
Shiny new wiper motor fitted and tested
Old 23-08-2017, 09:11 AM   #213
No more glass fuse box
The car is now protected by 33 fuses and 7 relays, wiring mission almost done, just needs extending out to the headlights and rear lighting loom making.
Hard lines for the brakes mocked up
Old 23-08-2017, 03:52 PM   #214
looking good
Old 30-08-2017, 12:31 PM   #215
Can't believe the wiring is almost finished, have done the loom to the boot now as well, just the headlight connectors left to add. Managed to get a pair of new headlights that take a H4 bulb instead of the old type
Next big job is get it ready for paint, should keep me busy for a few weeks I think. Aerocatches turned up for the bonnet. I've got some struts on the shelf too but I'm not sure there is room to fit one, having the original bonnet prop isn't an issue really.
I'll add the wiring in for this as well, a little extra choo choo for it!
No room for the bottle the boot so behind the passenger seat is looking likely. I think wizards do an adapter for a 'blow down' tube to exit through the floor from the relief valve. I think it will be ok for the moment though long as it's not pointing at me!
Old 03-09-2017, 09:23 PM   #216
Wiring done! Milestone, even tested the speedo which seems to work.
Front brake lines all in and done, odd to be working on a car and not getting dirty. Need to finsh the rear lines and fit new rear cylinders then it will have brakes.
Next job modding the bonnet to fit some Aerocatches, then on with the sanding.
Old 04-09-2017, 11:16 AM   #217
Ken555
Ken555's Avatar
CC: 1590
ECU: PW0 with custom map
http://www.ebay.co.uk/itm/162655171865
Looks like you tried the wrong conversion
Ken555 is offline   Reply With Quote
Old 04-09-2017, 11:22 AM   #218
wtf
Old 04-09-2017, 11:51 AM   #219
Phaeton
Phaeton's Avatar
Wonder what it says on the V5C
Old 04-09-2017, 12:16 PM   #220
Ken555
Ken555's Avatar
CC: 1590
Originally Posted by phaeton View Post
wonder what it says on the v5c
volkswagen 1200a
Old 04-09-2017, 12:20 PM   #221
Phaeton
Phaeton's Avatar
volkswagen 1200a
LOL Missed that
Old 04-09-2017, 01:27 PM   #222
Originally Posted by MattG View Post
wtf
lol, maybe he saw your Subaru conversions and thought "I know what I can try"
For full effect it just needs the "Miss Daisy" spec engine conversion (check out Miss Daisy build on Mighty Car Mods on Youtube )
Old 04-09-2017, 04:59 PM   #223
"Drives, handles and sounds like a beetle"
I'm not so sure that's a selling point?!
Old 04-09-2017, 05:50 PM   #224
Haha yeah, same guy that put the Allegro body on the corvette. It does look rather good, I even put a bid in.
Needs a scooby engine though as they made it slower than the original!
Old 04-09-2017, 06:18 PM   #225
I was thinking to myself that it seemed a pointless conversion and he's potentially made it a worse car (although that takes a certain level of skill!).
I like the hotrod look it has but otherwise it seems backwards, bung a Porsche lump or a Scooby lump as you've said and it would be a really cool car then!
You must be able to see light at the end of the tunnel by now?!
