Old 19-06-2018, 06:47 AM   #541
Purtsi
Purtsi's Avatar
I made a new rooflining. Mini got a lot quieter because of it
I have a cunning plan...
Old 20-06-2018, 06:16 AM   #542
cedric998
very good idea to kill vibrations and noise !!
doesn't weigh a lot and looks nice.
brgds
chris
Old 07-08-2018, 07:21 PM   #543
Purtsi
Purtsi's Avatar
Had few free hours to spend in the garage so I tacked the manifold and downpipe in place.
I'll keep the actuator in the original place, I just need to redo the shaft in Z-shape for it to work. Otherwise it'll poke too far out.
I Know for sure that the whole thing will come around 5cm through the grill. Main concern is that will any of the parts hit the flip front when coming down or not...
Also, noticed today that the radiator is leaking and it'll need to get fixed. Also noticed when i drove the car to the garage that the electricity is completely out. Doesn't help fixing it either...
Old 22-08-2018, 09:03 PM   #544
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
Looking good
Old 25-08-2018, 06:16 PM   #545
Purtsi
Purtsi's Avatar
Exhaust manifold is now finished. Not the most beautiful but as a first try I just hope it works somehow!
Downpipe is tacked together. It'll need some major hacking but that will need to wait till I have time to lift the car up and see how it all fits.
Old 16-10-2018, 06:14 AM   #546
Purtsi
Purtsi's Avatar
Slow progress but progress anyway...
I opened the TB hole just a bit for the MG TB.
I bought a second hand Land Rover IC for a box of beer. Needs a lot of modifications to get it fit. Idea is to install it over the TB.
First mods done. Most likely I'll make new inlet/outlets and then get it welded.
All the intercooler piping will be 2" OD but I noticed that in the IC the holes are about 40mm due it being a cast alloy. Does that matter much? I could enlarge those to about 46mm with a bit of work...
Old 16-10-2018, 06:16 AM   #547
Marcus Nordblom
ECU: 40mm mikuni rs
looking good, neat package
Old 16-10-2018, 06:33 AM   #548
Purtsi
Purtsi's Avatar
Tack Marcus
Old 30-10-2018, 09:59 AM   #549
Purtsi
Purtsi's Avatar
It's time for a brake upgrade
I removed the ITBs and started mocking up the TB and intercooler. It fits just and just...
And now all gauges are in front of me behind the wheel
Old 10-11-2018, 10:54 AM   #550
DVO
DVO's Avatar
ECU: Chipped
The intercooler in that spot won't be of much use I think, partly covered, on top of the engine and rather small. A Toyota Starlet Turbo has the intercooler on top of the engine itself, but with the Mini bonnet there is not enough space.
Maybe put a narrow intercooler just above your outlet manifold using a heatshield. Most a-series turbo cars also put it there.
Dennis
Very nice brakes btw
Old 10-11-2018, 06:03 PM   #551
Purtsi
Purtsi's Avatar
Unfortunately there isn't enough space under the bonnet if IC is placed over the exhaust manifold. At least according my calculations. Not an issue with clubman front end but it sure is with round nose.
I know the location isn't ideal where it will be but it's better than no IC at all. Most likely I'll made a scooby style bonnet scoop at some point to get some air flow to it and actually about 90% (rough guess) of the core is directly under that hole.
Old 27-11-2018, 07:02 AM   #552
Purtsi
Purtsi's Avatar
It's in! Kinda...
More pics coming later on this week about the brakes etc...
Old 28-11-2018, 06:28 AM   #553
Purtsi
Purtsi's Avatar
Brake servo is in with some added lightness. Now I just wait till I get my order from minispares including new brake master cylinder so that I can finish the brakes. Then there's only 999 other things to do...
Old 28-11-2018, 09:18 PM   #554
DVO
DVO's Avatar
ECU: Chipped
It is becoming very crowded
Dennis
Old 29-11-2018, 06:57 AM   #555
Purtsi
Purtsi's Avatar
Dennis
It sure is. Flip front helps a lot though =P
