Old 11-05-2018, 05:15 PM   #1
Default Pg1 gearbox rebuild
WHY ARE THESE GEARBOX'S SUCH A PAIN IN THE PEACH!!!!!! aaaarrrrrggggghhhhh 2 hours to get the top casing on and built back up because of the 5th gear dog, then the dog just drops down another 3mm and it drops on no problem, and now I still cant get 5th, so back out it comes again to see if I've bent another baulk ring wire FFS!
And here is the offending wire ring!
IMG_3732 by Keith Thornburn, on Flickr
IMG_3731 by Keith Thornburn, on Flickr
Old 12-05-2018, 07:42 AM   #2
In the post for you, first class.
Old 12-05-2018, 07:45 AM   #3
Cheers !
Old 12-05-2018, 08:17 AM   #4
Youíve done well there! Donít worry too much if you do another one, Andrew probably a dozen more
Old 12-05-2018, 08:42 PM   #5
Yeah he probably has the down side is once you remove the ring, the gearbox can only be used for spares I had a look on Rimmers and you can buy the complete 5th gear syncro including the baulk ring & wire spring for £ 374
