Old 11-04-2018, 09:43 AM   #1
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Default K maps ecu
Going to be running the turbo engine on a k maps ecu with a manual boost controller.
Do I still need a stepspeed ecu or will any mems3 ecu do seen as Iíll be using the manual boost controller?
Old 11-04-2018, 09:55 AM   #2
Readie
Readie's Avatar
ECU: KMAPS TURBO
Any mems3 ecu is fine
Readie is offline   Reply With Quote
Old 11-04-2018, 02:05 PM   #3
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Thatís great, cheers
Next question, does anyone have a mems 3 ecu, 5as and preferably two fobs that they donít need before I head to eBay for a look
Old 13-04-2018, 09:12 AM   #4
Readie
Readie's Avatar
ECU: KMAPS TURBO
Kmaps will supply an ECU if you need it although its cheaper to buy one and send it to them. They will also remove the immobiliser at the same time as the remap if you ask saving the need to get a matching ecu and fob
Old 13-04-2018, 11:00 AM   #5
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
My cars ignition is toggle switches and a push button start with no key at all so Iím wanting to keep the immobiliser so it has some security. Had a look on eBay and they all seem to have one fob, would rather two so I have a spare
Old 13-04-2018, 12:46 PM   #6
You can get replacement fobs, some are remanufactured originals and others are universal fobs, only problem is then you need to have them programmed.
I would have the 5AS removed and then look at other immobiliser options, I looked at a keyless starter option that would have replaced the ignition with a push button and a key fob that just needed to be on your person.
Old 13-04-2018, 03:17 PM   #7
Different people and opinions.
I think the Rover immobiliser works well. People who remove it seem to think it solves problems but the truth is, it's a security device and not complicated to get working. The small issues it causes getting set up could prevent your car from being stolen.
I would ask someone breaking an MG for it before they start selling bits. That way you get the best bits.
https://www.ebay.co.uk/itm/MK1-ROVER...oAAOSwZVJaxOeB
Old 13-04-2018, 05:47 PM   #8
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
It’s already wired up for the 5as so might as well use it, I’ll keep looking for a decent priced set with two fobs or just get one with one fob if I can’t find any
Edit: just noticed your link Andrew, cheers. Guessing the engine should fire up with the 1.6 ecu before it’s mapped just to check my wiring?
Old 13-04-2018, 08:27 PM   #9
I understand it should start but obviously not run the turbo. I think it runs lean so not advisable for any length of time.
Personally, I would get the remapped ECU done.
Old 14-04-2018, 03:10 PM   #10
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Yeh, I wouldnít run it long at all, just want to make sure itís going to fire up to check my wiring
