#31 |
![]() It’s not as if it’s pain the ass to get off. You must be curious exactly how that happened? Sent from my iPhone using Tapatalk |
#32 | |
![]() Quote:
![]() Last edited by edk83; 01-05-2018 at 03:26 PM. |
#33 |
![]() Fair enough, glad they realised it wasn’t reliable enough! Sent from my iPhone using Tapatalk |
#34 |
#35 |
Yeah, I had one die on me years ago, expensive for a new MFU!
#36 |
My engines out of a TF and has the MFU, I think the later ZR's have them built into the engine bay fuse box with individual relays rather than 1 big 1.
#37 |
Yes I used the mgzr fusebox, it's very handy for power distribution to the in car fuse boxes via switched relays.
Main power leads I've only got battery to starter and one lead to fusebox, job done, everything else distributes from that. Making use of the outputs for the mgzr lights and abs to my in car power distribution (fuse boxes). ![]() You can see the two black relays at the top of the pic, they are fed from the 40a abs fuse and 40a lighting fuse in the zr fusebox. They have their own built in fuses too, and supply a fuse box each in the car. The two 40a flat fuses you can see are 'igniton' and 'aux igntion' one powers my always live fusebox which in turn switches the other two on, also runs lights and ran fan manual override, things I want always on. The other one supplies the power to my airhorn relay. The fuse box contains the yellow fuelpump, ecu, starter and rad fan relays, they are all the same so interchangeable. Last edited by edk83; 02-05-2018 at 01:27 PM. |
#38 |
Like this
![]() Last edited by edk83; 02-05-2018 at 01:39 PM. |
#39 |
ECU: Emerald
Snapped the fuel rail by pulling to hard on the fuel hose broke the end off the rail
#40 |
Pretty impressive! No need to take your frustrations out on other people’s engines now!
![]() I’ve been hanging off hoses trying to release them before, they can be a pain in the ass to get off sometimes, I’ve got a little hook tool that works well at getting underneath to break the seal, they usually come much easier then. Sent from my iPhone using Tapatalk |
#41 |
"I’ve got a little hook tool that works well at getting underneath to break the seal, they usually come much easier then."
![]() Is that how Michelle got pregnant? ![]() |
#42 | |
![]() Quote:
I’ve got a video somewhere that shows how Michelle got pregnant Sent from my iPhone using Tapatalk |
#43 |
#44 | ||
ECU: Mems 3
![]() Quote:
Now that I like. Quote:
![]() ![]() Last edited by CooperWorks; 02-05-2018 at 11:06 PM. |
#45 |
[QUOTE=CooperWorks;378650]Now that I like.
You have got any room for that in your engine bay! plus it's Rover not Lotus! ![]() |
Thread Tools | |
Display Modes | |
